Class D audio power amplifier research
Old 23rd October 2008, 04:10 PM   #31
rob mullen is offline rob mullen  Ireland
Ok i have the Questionnaire ready to email out. Just PM me with your email address and i can send it on.
Old 15th November 2008, 09:30 PM   #32
starstruck is offline starstruck  United Kingdom
Thought you might be interested in a customers point of view.
I just did a big outdoor gig with an ex winner of the x factor to around 10000 people.
We used a Meyer PA that used class D amps. There benifits to the live PA sector are :
Weight ! These amps were around 2KW per channel and they were only 1U high ! It would normally take a 3U box that weighs a ton! to get that amount of power. You try humping them about all day and you will soon switch to class D
Heat - When you use BIG class H amps they run hot , VERY HOT. The class D's hardly warmed up !! Also did you know that when semicinducters are manufatured they artificialy age them (burn-in) by powering them on and heating them up. So if your electronics run hot it will reduce its life span !!
Price - You get a lot of bang for your buck
Efficiency - If you are trying to run a huge system off a 32A supply every bit of power you can save helps.
And sound wise they sounded GREAT.
Hope this helps
Starstruck
Class D audio power amplifier researchHide this!Advertise here!
ANA Audio Research APA 8 Power Amplifier. Heard of it? Junior Solid State 0 1st August 2007 12:56 AM
class D audio power amplifier using tas 5261 IC. surya krishna Class D 14 5th July 2007 12:14 PM
Copyright ©1999-2017 diyAudio
