| Class D Switching Power Amplifiers and Power D/A conversion |
hi all ive got 4x ucd 400 hg modules and would like to bridge them to make a 2x 800w stereo amplifier
ive read on this forum that it can be done but i cant find it by searching can anyone offer any advice on how to do it cheers |
#2 |
diyAudio Moderator Emeritus
The UcD modules have a differential input, so you just reverse the input connections on one module and connect the speaker to the output of each module. There is a way to synchronize the switching frequencies of each module but I don't believe it is necessary and I can't remember which thread it was in. It may even be in the literature on the hypex website.
Brian |
#3 |
hi mate
cheers so just to clarify all i need to do is reverse the polarity on the input + and- on one of the modules and then run the speaker hot and cold from both modules to the speaker terninals as per normal exept that both modules outputs will be connected to the same pair of binding posts in parallel |
#4 | |
The amplifiers are single ended so the "-" output is just ground. It is not used on either amplifier in bridge configuration. The "+" signal to the speaker is connected to the "+" output of the amplifier with its inputs the "right way round". (So it gives the normal signal at its output.) The "-" signal to the speaker is connected to the "+" output of the amplifier with its inputs inverted. (So it gives the opposite signal at its output.) Note that for a given voltage out each amplifier is providing twice the current that it would normally, so the minimum load impedance is doubled. Ken |
#5 |
thanks
i think i have it now so the speaker cold on each module is no longer used i just use the + from one module to the + of the speaker and the + of the other inverted module to the - of the speaker i presume the power supply to the boards still gets connected as per normal |
| Hypex UCD400HG with HxR (and without!) | cowanrg | Swap Meet | 7 | 4th July 2009 07:03 AM |
| 5 channel UCD400HG Kit | ngiachin | Swap Meet | 3 | 24th June 2008 05:29 PM |
| UcD400HG amp finished | Alfetta87 | Class D | 19 | 1st May 2008 11:22 AM |
| UcD400hg monoblocks done | croger | Class D | 25 | 24th March 2008 10:50 AM |
| UcD400HG MonoBlocks project... help please | croger | Class D | 18 | 15th February 2008 10:55 AM |
