Identify part on SI T-amp pcb (I burned it...)
Old 17th September 2008, 12:20 PM   #1
jaste is offline jaste  Sweden
Default Identify part on SI T-amp pcb (I burned it...)
Hi! Coming home late at night dying to get into bed and fall asleep listening through my new t-amp I accidentely mixed the polaritys on my batteri and the t-amp started smoking...
From what I can see there is only one little part damaged and I thought I might as well try to replace it and see if it works.
The part is labeled "FB5" on the pcb and it looks like this:
Can someone please tell me what it is?
Old 17th September 2008, 12:51 PM   #2
audio1st is offline audio1st  United Kingdom
audio1st's Avatar
It is either a fuse or a ferrite bead. I have never had that board so can't be more precise.
If you promise not to make the same mistake again you could just bridge that item. Also you should check FB9.
To check that they have been damaged you will need to read the resistance across them with a meter set to ohms, should read something close to zero.
Old 17th September 2008, 01:45 PM   #3
theAnonymous1 is offline theAnonymous1  United States
theAnonymous1's Avatar
I don't know why that picture has the ferrite beads labeled "fuses". They are there for EMI suppression, not as fuses.
Anyway, that burned ferrite bead is probably the least of your problems. There is a good chance the IC is toast.
Old 17th September 2008, 03:38 PM   #4
Thank you very much for your help! If I would like to by a new feriite bed to solder in place instead what should I look for?
Old 17th September 2008, 03:57 PM   #5
You don't need to buy a new ferrite bead to see if the board is still functional or not. If it is burned open circuit you can just jumper the pads with a piece of wire. It's not a critical component, so if the amp is still good it should work without it.
Old 19th September 2008, 04:28 AM   #6
Pano is offline Pano  United States
Pano's Avatar
It's a Ferrite Bead. Used to clean up the incoming power.
You can replace it with a wire jumper - or a fuse, or a diode (to keep reverse polarity out)
Take the Speaker Voltage Test!
Identify part on SI T-amp pcb (I burned it...)Hide this!Advertise here!
Please help this Newb identify this part. Paulcocom Parts 2 11th September 2007 05:18 AM
what part can take the place of ST part VB408B completely peterchen88 Parts 0 8th September 2007 06:45 AM
toshiba sd-3950: help me identify a damaged part xcortes Digital Source 0 24th July 2005 03:30 PM
I burned my Aleph 3! Please help! Jesse Pass Labs 25 26th October 2003 02:56 PM
help identify'n a part ??? kaukasion Solid State 7 4th June 2003 03:44 AM
Copyright ©1999-2017 diyAudio
