TDA8950 ClassD chip. - Page 2 - diyAudio
Go Back   Home > Forums > Amplifiers > Class D
Old 9th April 2010, 06:26 PM   #11
need your help plz . need to install tda8920bj in my car as mono output
Old 10th April 2010, 01:40 AM   #12
ontoaba is offline ontoaba  Indonesia
ontoaba's Avatar
A company right here (POLYTRON) used it, but the filter inductor is very hot, it has good protection and sounds better than usual class-D. It is cheap and very small indeed, my friend designed for them. If there someone near only, may I could help.
He also told me that this thing could very easily driven real 120Wrms into 4ohm.
Old 3rd May 2010, 06:58 PM   #13
Ar4 is offline Ar4  Latvia
Send a message via Skype™ to Ar4
Default Any help?
Hello!
Anyone can provide single layer PCB design for TDA8950 please?
Old 4th May 2010, 02:12 AM   #14
authlxl is offline authlxl  China
SINEWAVE ELECTRONICS CO.,LTD
Send a message via MSN to authlxl
Oh! we have finished modules used TDA8950TH OR TDA8920BTH,anybody like ,pls connect us.SMPS and class D all in one.
Old 4th May 2010, 02:16 AM   #15
Upload picture here,low cost ,stable work,but sound not better like TAS5630 or ta2022.
Old 24th November 2010, 01:40 PM   #16
Another batch TDA8950TH chip arrived days ago,we have revised the circuit and build one newer module,of course,include CLASS D and SMPS,sound good.
Key Specifications:
POWER OUT:
2150W/ 4Ω /10%THD/SE MODE
2100W/ 4Ω / 0.05%THD / SE MODE
1300W/ 8Ω /10%THD/ BTL MODE
FREQUENCY RESPONSE: THD+N ≤0.05% / 20-20KHz / 1dB/1W
INPUT SENSITIVITY: 0dB(1Vrms)
POWER SUPPLY: 110VAC OR 220VAC 50 OR 60Hz
AUXILIARY POWER: +/- 15V/100mA and +5V/200mA
DIMENSIONS: 160MM(length)*80(width)*50mm(height)
WEIGHT: 0.54Kg
Old 2nd June 2011, 07:39 AM   #17
Default Duad TDA8950+SMPS IN ONE BOARD
We have finsh our new tda8950 board,performance good .sound good.
proamp design.dynamic compressor and ocp/otp/uvp/ovp protection inside.
POWER OUT: 1100W/ 4Ω /0.05%THD/4SE MODE
2200W/ 8Ω / 0.05%THD / 2BTL MODE
1400W/ 4Ω /1%THD/ PBTL MODE
COMPRESSOR THRESHOLD: +4dBu
AUXILIARY POWER: +/- 15V/100mA and +5V/200mArms
DIMENSIONS: 250MM(length)*65mm(width)*39mm(height)
WEIGHT: 0.47Kg
Old 4th June 2011, 01:57 PM   #18
lithoc is offline lithoc  Malaysia
lithoc's Avatar
Hi authlxl,
I think TDA8953/4 would be a better choice for proamp.
Old 5th June 2011, 05:19 AM   #19
good suggestion,but we only have tda8954J,we test time ago,feel no good.we will try it later.
TDA8950 works stable and sound powerful.only our experience.
Thanks!
Old 14th June 2011, 07:41 AM   #20
lithoc's Avatar
TDA8920 & TDA8950 is pin to pin compatible.
How does the sound quality compare with both?
Some sources even say its even better than LM3886.
I'm just wondering, anyone have tried?
New to ClassD DarkOne Class D 2 24th September 2006 04:11 PM
looking for classD follower lumanauw Class D 2 17th October 2005 12:54 AM
Learning about classD lumanauw Class D 34 24th March 2005 01:39 AM
GC VS classD etalon90 Chip Amps 0 3rd November 2004 05:29 PM
classD Vs gainclone etalon90 Class D 0 2nd November 2004 10:07 PM
Copyright 1999-2017 diyAudio
