Go Back   Home > Forums > Amplifiers > Class D
Old 11th September 2008, 03:21 PM   #1
atldiyr is offline atldiyr  United States
Default First DIY project, Charlize problem
I recently bought a Charlize2 amp and after making all the solder connections am only getting sound from one channel, the left channel. The right channel is dead. When I turn on power to the amp which I measured at 12.57 vdc (I'm using a lithium-ion 11.1 v battery) I hear a distinct click from the left speaker and a fainter click in the right speaker. I did a continuity check from the mp3 player I'm using as a source up to where the input is soldered to the board. My eyesight is not the greatest but all the solder connections look alright to me. Is there a way to troubleshoot this - I don't have access to an oscilloscope. I don't see any physical damage to any of the components. (And of course have not seen any smoke from anything.) I don't suppose it would make any sense to take it to some type of audio repair, would it? By the way the MP3 player I hooked it up to was an iRiver model and have not seen any ill effects to the player from all of this.
Thanks,
Mike
Old 11th September 2008, 07:14 PM   #2
Did you try diyparadise.com?
That is where Charlize is from. I am sure Yeo would be glad to assist you in getting it going. I have the original version and its a fantastic amp.
Andrew
None of us are leaving this world alive. Enjoy it responsibly as you may.
Old 12th September 2008, 07:03 AM   #3
Thanks for the advice - I'll try that.
Old 15th September 2008, 07:42 PM   #4
since you can hear a click on both speakers it looks like you may have a problem on the input part.
Did you check ?:
- Signal and ground are not reversed on both inputs ?
- Measure DC offset on inputs ?
- Bad interconnect connexion from your iriver (try moving the cable while playing) ?
Hope this helps.
Problem with Charlize amp Nikola Krivorov Class D 1 6th February 2009 03:44 PM
Charlize Drop-Out Problem serengetiplains Class D 4 27th August 2006 08:20 AM
Problem with my charlize Radian Class D 0 3rd June 2006 08:12 AM
charlize problem jonastus Class D 4 13th May 2006 01:44 PM
Charlize input cap problem - Help! KT Class D 9 10th February 2006 03:22 PM
Page generated in 0.07535 seconds (71.29% PHP - 28.71% MySQL) with 10 queries
