| Class D Switching Power Amplifiers and Power D/A conversion |
hi..me and my friend want to make a 500watts class d amp with IRS2092 chip..we have different transistors..i am planning to use irf540st(low gate charge) and my friend is gonna use lateral type 250watts rms class d mosfet.its here
http://www.classd.ltd.uk/product.php...cat=266&page=1 i made a simple class d design with ir2110s some years ago but now i am making class a amps and forgot which LC filter which core (mpp thinz? or ferrite)may i use for this amps.i think the sampling frequency will be 300kHz.it will sound at 20Hz-20kHz.my friend want to have a quality filter.he always want to have quality stuff . can you give me a good advice.thanks
#2 |
Air Core filter sounds the best in any ClassD Amp, but be sure to shield the whole apparatus to avoid EMI problems.
Best of luck ajazz |
#3 |
do you mean no core?just copper?how can we get 5amps 20uh copper filter?we dont have lcr meter.its measurement was on my university physics book in the past i cant find it now
thanks
#4 |
As per my experience for a supply upto +-80V a Air core inductor made of 16G litz wire on a former size of 1inch ID and 1inch width wound with approx 100 turns should give you the required inductunce. You may have to experiment with the No of turns to get the required uh. 40uh + .47uf to ground recommended for best performance as per various datasheets.
All the best |
#5 |
T106-2 Iron powder core.
#6 | |
please, show us a picture
best regards Kay |
#7 |
Air core at those voltage levels results in too high stray magnetic fields. It's not a good idea.
Those laterals doesn't even seem to have a datasheet available. They are usually intended for linear applications. They may exhibit terrible switching performance.
I use to feel like the small child in The Emperor's New Clothes tale
#8 |
http://www.classd.ltd.uk/Datasheets/...D%20NX%27s.pdf they make class d amps using these mosfets..they are very good amps
and also now i connected it to my single ended class a amp..it sounds good also ![]() but my single ended amp is for using vertical mos irfp150n..which resistor values should i change? amp is ras10 single ended.. |
#9 |
http://www.classd.ltd.uk/Datasheets...CD%20NX%27s.pdf
Those are not class d amps |
#10 |
Sorry for the photo quality. This trial amp was for the DIY and it works well, but later scraped the idea because of costly components.
| 500watts car amp. VS 1000 watts subwoofer | el_cobra | Car Audio | 9 | 2nd September 2008 09:00 PM |
| 500watts Amplifier help | darkkiller | Solid State | 29 | 30th April 2008 11:36 PM |
| need help wana change 60-Hz twin-T notch filter to 279 Hz filter | prorms | Solid State | 0 | 9th February 2008 11:38 PM |
| active filter from rod elliot and sub filter questions | wuffer | Parts | 0 | 2nd October 2005 01:12 PM |
| chassis-mounted filter or IEC plug filter | jarthel | Solid State | 7 | 11th March 2002 10:17 AM |
| Page generated in 0.11634 seconds (80.37% PHP - 19.63% MySQL) with 11 queries |
