Go Back   Home > Forums > Amplifiers > Class D
Old 11th August 2008, 01:19 PM   #1
diyAudio Moderator Emeritus
Default Is this really working?
Patent #6844777 or #6937092, are these patents really working in reality (for high quality classD amp)?
Isn't that transformer coupled signal has a certain minimum pulse width to work well?
If it works, we can make high quality, high power classD with only IRFZ44
Old 11th August 2008, 01:36 PM   #2
Account Disabled
For a single advantage such simplicity is not without cost. Why not wrap a quality control loop around it, if it's estable enough pyre can manufacture it and sell it back to us. Or is this better seen as one of those open loop things.
Old 11th August 2008, 01:48 PM   #3
If the output always 50%-50% there will be no trouble. But for small/large duty cycle, what will happen? Considering the set-reset of Volt-Second area.
Old 11th August 2008, 02:20 PM   #4
darkfenriz's Avatar
LOL
Since the Switch-mode transformer cannot transform low frequency audio signals, then one should use heavy tube-style transformer.
Then why class-D ??
Authors don't seem familiar with the existance of DC-DC converters (in 2003).
Old 11th August 2008, 03:08 PM   #5
luka is offline luka  Slovenia
luka's Avatar
Send a message via MSN to luka
Originally posted by darkfenriz
LOL
LOL indeed
home page @ http://www.classdaudio.co.cc @ 24/7 all year long
I FEEL SLOVENIA
Old 11th August 2008, 03:26 PM   #6
It is theoretically possible to build such an amplifier but the technical requirements for the transformers wouldn't give any advantages over ANY other amp topology.
Apart from that this has been discussed in web forums etc so many times that it shouldn't be patentable in the first place.
Charles
Old 11th August 2008, 04:05 PM   #7
In patent #6844777, the key is fig.1 to fig.2. Full bridge classD is being isolated by a transformer. If fig.1 is working at 400khz, then the transformer in fig2 should be built by -2 material (maybe T130-2).
Then the carrier is eliminated by L-C like usual.
Then we can move to fig.3, the push-pull one.
At first glance, it seems to be working.
But when I experiment with transformer working with very narrow (or very wide) duty cycle, the weakness of transformer appear. I cannot fool the Volt-Second product of a quadrant.
Old 12th August 2008, 02:45 AM   #8
If this really works, it would be very nice. I can make +/-150V swing amp only with IRFZ44N (don't have to look for quality high voltage mosfet), in push-pull mode (like primary of car SMPS) without the need for level shifter etc Just adjust Np:Ns.
Old 12th August 2008, 03:03 AM   #9
Send a message via Yahoo to thespeakerguy
Default I built an xformer Class D
I tried similar in the lab once. Used a MAX4295 open-loop Class D amp, driving N FETs. It dis work, doing aabout 4 watts into 8ohms at 1kHz or so. Anywhere below that it died, because this becomes close to DC flowing through the core.
With a large enough core it could be improved. it should have some feedback to correct for FET, voltage and xformr non linearities.
An alternative is to reverse the current in the transformer by having active rectifiers. This way no DC in the core.
Old 12th August 2008, 03:11 AM   #10
Hi, thespeakerguy,
That's an important restriction
Could you tell more about this?
Amp non working covik Solid State 0 12th November 2006 08:12 PM
WTB Krell KSA Mk2- working or non working Jozua Swap Meet 0 20th March 2006 11:14 AM
sub amp not working felzi Chip Amps 0 28th July 2005 05:29 AM
p3a not working, help! benmanf Solid State 9 27th May 2005 01:02 PM
Page generated in 0.10919 seconds (79.97% PHP - 20.03% MySQL) with 11 queries
