| Class D Switching Power Amplifiers and Power D/A conversion |
Hi, I'm new to the forum and new to class D amplifiers and hope you guys can help me out!
I have just taken over running of a music society at a university which is in need of an equipment overhaul. With regard to amplification the weight and size advantages of class D combined with SMPSs appeals very much to our storage/strength limited operation. So, I'm looking first to build an 'all in one box' bi-amp setup for a turbosound TFM330 floor monitor which requires LF: 800 W @ 8 ohms and HF: 200 W @ 8 ohms. Module manufacturers such as Hypex, Coldamp, and CADaudio all appear to provide potentially suitable candidates but maybe there's something out there i've missed. Are there any topologies which are generally accepted as superior for higher power applications? Anyway would be good to hear your thoughts/suggestions. What would you guys use for this application? Cheers Ian |
#2 |
Hi!
A possible solution is my home-made sub amp: http://users.hszk.bme.hu/~sp215/fors...D%20bottom.jpg http://users.hszk.bme.hu/~sp215/fors...%20top%202.jpg I mentioned it only because it's just exactly what you are searching for: 800 W sin, 1200 W music power, 8 ohm (protection trips at ~5,5 ohm), power supply on board. Other features: - balanced input, - 0 dB indicator, - 2nd order LPF (150 Hz, or what you want), - 2nd order HPF (25 Hz), - S/N >=100 dB, - THD<=0,2% (@ 500 W, 30-1000 Hz), - Damping factor >=150 (@ 30-2000 Hz) - Resonant power supply (low interference), - efficiency at nominal power: 96 % (supply), 94 % (amplifier), - idle power consumption: ~ 25 W. - mass: 1,4 kg, - dimensions: 16*26*6 cm. Output signal at clipping (2 ms/div, 50V/div; 50 Hz, 117 Vpeak, 850 W): http://users.hszk.bme.hu/~sp215/elektro/800W%208ohm.jpg |
#3 |
Thanks for the reply! Can you tell me more about the electronic design of that amp?
#4 |
Nice Pafi... really nice!
#5 |
Hi Pafi
As always, this amp with smps looks great, glad to hear it works as you want... |
#6 |
Thank you!
hilly! What would you like to know? It's an UcD based amp, single ended, with +/-145-150 V idle supply voltage. The PSU is not stabilized, but it have short circuit protection. It's a modified LLC converter. |
#7 |
How about the 41hz.com Truepath kits?
col.
http://www.minirig.org.au |
#8 |
Hypex will have their 2kW (4 ohms) UcD modules done soon.
| Driver recommendations for vocal sound reinforcement | mx2 | Multi-Way | 2 | 6th January 2008 11:15 PM |
| Sound reinforcement 'line arrays' | BassAwdyO | Multi-Way | 21 | 18th November 2006 12:40 AM |
| Sound Reinforcement amplifier design | Tim Farrant | Solid State | 1 | 15th December 2004 12:58 AM |
| DIY JBL 4 Way Sound Reinforcement | Dave Goodhew | Multi-Way | 16 | 16th June 2002 03:27 PM |
| DJ/Sound Reinforcement Subwoofer Type? | ogp | Subwoofers | 15 | 17th November 2001 01:28 AM |
| Page generated in 0.10200 seconds (78.91% PHP - 21.09% MySQL) with 10 queries |
