t-amp help
t-amp help
Old 2nd August 2008, 03:34 PM   #1
kankara is offline kankara  Hungary
Default t-amp help
hi everyone.
try to bridge the C4 like the tweak of audio1st i burned the foot on PCB.
there is some chance to recover the T-amp or is better put on the dustbin?
thanks for your help.
robertor
Old 3rd August 2008, 11:16 PM   #2
Buckapound is offline Buckapound  United States
Hi Robertor,
It's not exactly clear what damage you did to the board, but "burned the foot" sounds like you may have destroyed the pad on the circuit board where the capacitor connects.
If so, all is probably not lost. All of those circuit board traces go somewhere, so you should be able to follow it to an undamaged area and with a sharp knife or scalpel, carefully scrape away the coating to reveal bare copper. Use a very thin wire (I usually take apart a piece of stranded wire and use one of the strands) to connect whatever needs connecting.
I will say that when working with these small surface-mount boards, it is very important to have a strong magnifier, good lighting and a very sharp, pointed soldering iron. Flux in a pen is helpful also, and it is much easier with the old lead/tin solder. ROHS silver solder is misery for this kind of hand work.
Keep working on it. It's amazing the kind of horrible messes you can fix!
--Buckapound
Old 4th August 2008, 04:07 PM   #3
pincellone is offline pincellone  Italy
Sorted-out (Risolto!)
t-amp helpHide this!Advertise here!
Resources saved on this page: MySQL 17.65%
Copyright ©1999-2017 diyAudio
