Distortion problems on my Charlize 2
Old 24th July 2008, 03:07 PM   #11
Rafoo is offline Rafoo  France
Oh ! OK I get it, I'm sorry I did not understand the first time.
Just 2 questions :
- There is absolutely no contact between the input of the supply (230V 50Hz) and the output (even the grounds). Isn't it enough ?
- The same question as before : if the input ground of the charlize is at 2.5V, how can I connect it to a soucre with an output ground at 0V ?
Old 24th July 2008, 03:12 PM   #12
Lostcause is offline Lostcause  United Kingdom
Lostcause's Avatar
Hi, dont worry it confused the hell out of me first time round
Think of the 'ground' as the negative rail rather than the 'earth' pin and it becomes clearer.
It's only @ 2.5V potential, only if it can see it's own negative rail will it become that... I think that's how to put it? I'm no EE that's for sure!
Old 24th July 2008, 04:09 PM   #13
Ah yes your right, ground is different than earth. But still, I don't know if the source really like it ^^
I'll try to find a different power supply and do some tests but I'm not sure of the result. It's maybe easier to undo the mod of the charlize 2 and put back some input caps and wire the input ground to the pin 7 of the ta2020 ...
Old 24th July 2008, 05:42 PM   #14
Lostcause's Avatar
indeed that is the only way if you do not use batteries on one of the components.
Good luck
Distortion problems on my Charlize 2Hide this!Advertise here!
Charlize, with or without a pre? zacster Class D 12 17th May 2007 02:08 AM
WTB: Charlize mrbigtube Swap Meet 0 25th June 2006 07:18 PM
TVC for Charlize? Gremlin Class D 0 28th May 2006 01:38 PM
tda1541a distortion problems ash_dac Digital Source 3 10th September 2005 01:57 PM
Non Linear Distortion testing - Harmonic Distortion JMB Multi-Way 0 20th July 2004 02:54 PM
Copyright ©1999-2017 diyAudio
