B&O ICEpower modules any built? - Page 11 - diyAudio
Go Back   Home > Forums > Amplifiers > Class D
Old 21st January 2013, 08:12 PM   #101
Nisbeth is offline Nisbeth  Denmark
Nisbeth's Avatar
There's no replaceable fuse on the 200ASC. It uses an electronic fuse on the PCB which you shouldn't change.
/U.
Old 21st January 2013, 09:57 PM   #102
pbnmjk is offline pbnmjk  Chile
Thanks!!!
Old 20th February 2013, 09:39 PM   #103
karmau is offline karmau  Brazil
Send a message via MSN to karmau
Originally Posted by lugoshi View Post
Hello. Thank you for your answers.
I attached four pictures. You can look inside my A100 now.
I'am sure that PS audio made some modifications to 200ASC, and it's 110V gear now.
If you have photos of 220V version (2 sides ) in hi-res - that will be helpfull.
thx for your help
this and a trio a100 right? I need the drawing board input signal, would be grateful
mauricio
Old 20th February 2013, 09:50 PM   #104
thx for your help
Originally Posted by theAnonymous1 View Post
I've been playing with the 200ASC modules from YFW and I have to say I'm pleased with my purchase (and glad I got them before the price jumped to $199).
They sound as good as my junk test speakers will allow them sound. And no, the highs are not missing or rolled-off like some have suggested.
They may only be ~40W amplifiers, but that is perfectly fine with my neighbors. If I played them even close to clipping I would probably have someone banging on my front door.
I replaced the 50v 560uF supply cap with a Panasonic FC 63v 820uF. I also added two additional 63v 820uF caps across the J2 PS header.
what difference in power 200asc ice plate that has 2 capacitors and output plug to 47 volts
thank
mauricio
Old 21st February 2013, 08:02 PM   #105
dudaindc's Avatar
Mauricio - the information you need about the 200ASC modules is all here:
ICEpower Class D audio amplifiers
IcePower 200asc datasheet
IcePower 200asc brochure
"All measurements are wrong! Thus, measurement is the art of handling errors."
Old 21st February 2013, 10:22 PM   #106
Adding too much capacitance to the power supply will make it break from the inrush current.
Brian Oppegaard
www.speakerpower.net
Old 23rd March 2013, 07:57 PM   #107
audiosteve's Avatar
I just finished this one using 200 ASC modules:
Amp in a Can
Nihilism is best done by professionals.
Icepower Modules spchu Class D 15 23rd May 2011 10:24 PM
New 3rd Generation ICEpower modules.... TheShaman Class D 8 16th February 2009 03:44 PM
Icepower car amps for modules? bwaslo Class D 3 10th September 2008 05:42 PM
Copyright 1999-2017 diyAudio
