Go Back   Home > Forums > Amplifiers > Class D
Old 13th November 2012, 06:42 AM   #91
lugoshi is offline lugoshi  Poland
Hello
This is my first post here. I am proud owner of PS AUDIO TRIO A100 amplifier.
Im very suprised - so little, tiny very good amp.
It has two B&O 200ASC modules inside. It is 110V version.
I want to do a voltage conversion to 220V. Guy from PS Audio said that is simpliest thing under the sun. But he don't want to tell what to do... Company secrets...
B&O too. You are my last chance.
Can you help me with my problem?
Old 18th November 2012, 04:03 AM   #92
Nisbeth is offline Nisbeth  Denmark
Nisbeth's Avatar
The 200ASC is universal mains so unless there is an extra PSU inside then you don't need to do anything. Can you take a picture of the insides please?
/U.
Old 18th November 2012, 04:38 AM   #93
john65b is offline john65b  United States
john65b's Avatar
Lugoshi,
Edit - no jumper o the 200ASC, but I think there is on on the 250ASP...
Anyway, just found my 200ASC - looks like it can take 110 or 220 input -50/60hz. The amp module is OK, the fuse on the PS Audio enclosure would need to be swapped for the 220V fuse. Take some pics, one of us will tell you what you need to do...
All right, but apart from the sanitation, medicine, education, wine, public order, irrigation, roads, the fresh water system and public health, what have the Romans ever done for us? Life of Brian
Old 20th November 2012, 07:19 AM   #94
tiefbassuebertr's Avatar
Originally Posted by lugoshi View Post
Hello
The power supply is a SMPS version. Without exactly knowledge and schematic diagram I would not dare to experiment.
Linn provides in its model "Brilliant" in an automatic recognition for mains voltage, if I recall right - go to post #5 about
Linn "LINTO" MC Preamp Schematic without SMPS - Schematic for SMPS wanted
more URL's:
http://www.psaudio.com/wp-content/up...rs-manual1.pdf
PS Audio Trio A-100 Photos request
PS Audio Endstufe Trio A-100
Who can post an detailled schematic diagram of PS and amp section from this modules?
from an other ICEPOWER module you will find a (not completly) schematic here (without SMPS):
Sanyo/B&O Icepower 200AC Rev.D, schematic about rev. engin., not complete finished
Old 20th November 2012, 11:36 AM   #95
john65b's Avatar
Edit:I beleive all you have to do is raise the 220V fuse rating by 2 (ie 5A to 10A) for 110V. There should be a notice of fuse rating on the back.
Isn't there a manual that came with it?
Old 26th November 2012, 09:41 PM   #96
Hello. Thank you for your answers.
I attached four pictures. You can look inside my A100 now.
I'am sure that PS audio made some modifications to 200ASC, and it's 110V gear now.
If you have photos of 220V version (2 sides ) in hi-res - that will be helpfull.
thx for your help
Old 27th November 2012, 06:00 PM   #97
mravlca is offline mravlca  Slovenia
mravlca's Avatar
Hi Lugoshi!
All you have to do is just plug in the 230V mains and you should be fine. As stated in the datasheet of 200ASC minimum voltage is 85V AC and maximum is 264V AC. If for example you look at the 125ASX2 module you'll see that there are two ranges of mains voltages and it is also noted that mains voltages should be selected with jumper prior to what you have.
Don't change any fuses or anything! If you look at your cell phone charger, which I believe is smps, you'll notice voltage range and you don't change any fuse if you go to the country which uses 230V!
Best Regards,
Ales
Old 29th November 2012, 09:05 PM   #98
Sorry, but I plugged my A100 to 220V, but something started to "buzz". I waited 1 second for power led but nothing happened. I disconnected amp to avoid damage. Now I'am using voltage conveter 110-220V. Amp is working fine without sign of damage. I don't want risk second time...
I wrote to PSAUDIO they said that conversion is simplest thing under the sun, but it's company secret. ;-)
Old 29th November 2012, 09:26 PM   #99
john65b's Avatar
I think your amp is fine, but if the front end (input) circuit is designed for 110v, you have to change something there...
Whoops, nevermind, the input board is getting power from the modules....
Old 20th January 2013, 10:19 PM   #100
pbnmjk is offline pbnmjk  Chile
Default where is Trio A100 fuse?
Hi, somebody can tell me where is PS Audio Trio A100 fuse please? I want to change it for a ceramic fuse, some recomendation?
Thanks in advance...
Icepower Modules spchu Class D 15 23rd May 2011 10:24 PM
New 3rd Generation ICEpower modules.... TheShaman Class D 8 16th February 2009 03:44 PM
Icepower car amps for modules? bwaslo Class D 3 10th September 2008 05:42 PM
Copyright ©1999-2013 diyAudio
