| Class D Switching Power Amplifiers and Power D/A conversion |
#21 |
This is not a problem because in my prototype i use a floating small smps
#22 |
It's a fruitless endeavor to try and educate a fool that rejoices in ignorance
#23 |
There are many different possible reason to cause strange things close to clipping. Without knowing anything about the actual circuit and without seeing the faulty signal, I think guessing is pointless.
BTW: I use only 1 uF, and still no problem with bootsrap voltage. :-) 81bas! 470 millifarad???
#24 |
Well, then try to use 1uF bootstrap capacitor in discrete UcD
#25 |
This is one of the reason why I haven't built it! (However it has some significant benefits.)
| Cracking sound from amp - help | Brit01 | Solid State | 5 | 8th August 2009 01:13 PM |
| Cracking/Static in Pre-Amp | TheVille | Solid State | 2 | 17th April 2009 07:42 PM |
| Popping Noise = Clipping ? | liggs17 | Tubes / Valves | 5 | 28th November 2006 07:16 PM |
| cracking noise in reference | Tony.ca | Multi-Way | 12 | 18th October 2006 07:20 PM |
| cracking noise in P3a | PetarLD | Solid State | 0 | 13th May 2004 04:03 AM |
| Page generated in 0.07017 seconds (71.21% PHP - 28.79% MySQL) with 11 queries |
