Control gain by changing supply voltage?
Old 18th June 2008, 11:14 AM   #11
oldeurope is offline oldeurope  Germany
Default yes
Originally #1 posted by preiter
Since a class-D amp works by switching on and off the supply voltage, would it be possible to control the gain by changing the supply voltage?
Would this be a viable form of volume control?
Yes, it is. And it is excellent.
See this one: link
http://d-amp.blogspot.com/
translated by google
Full dynamic range of the PWM at low volume settings.
Kind regards,
Darius
Old 18th June 2008, 12:30 PM   #12
phase_accurate is offline phase_accurate
It only works on open-loop designs. The original implementation was in the TacT amplifier (using a full-bridge output topology)where a lot of effort was made in order to get a supply voltage that is
1.) Controllable and
2.) very clean
TacT's IP was later bought by TI and their staff was recruited as well.
Charles
Control gain by changing supply voltage?Hide this!Advertise here!
Changing Gain of Sonic Impact Gen 2 unit ttan98 Class D 4 26th November 2008 04:34 PM
Too much gain - help with changing driver tube. colinB Tubes / Valves 15 21st November 2008 09:09 PM
Leach amp - regulated supply only for the voltage gain stages? velicko Solid State 2 21st January 2008 11:16 AM
I want to set up a digital control voltage supply xiaonan Power Supplies 11 7th September 2006 08:31 AM
Changing the NFB resistor to balance gain. troystg Solid State 6 7th May 2004 12:06 PM
