Go Back   Home > Forums > Amplifiers > Class D
Old 10th June 2008, 12:36 AM   #1
Default Surface mount drive components?
For an average class-D amp operating at say 200khz what kind of performance advantage will SMT give over the traditional threw hole style.
I know it will cost far less too.
Old 10th June 2008, 01:24 AM   #2
MartyM is offline MartyM  United States
MartyM's Avatar
Send a message via Yahoo to MartyM
I'm not really aware of "performance" advantages of SMT components, be they Class D amplifier ICs, passive components, or others.
But I can tell you this...when I design a PCB, SMT allows for:
1. Smaller PCB layout, possible up to 25-30% smaller for a compact board on that layer
2. Reduced copper traces (length & width)
3. Allows population of parts on both top and bottom of the board for an even more compact board! (Assuming constraints allow this)
4. Can eliminated drilling holes and thru-hole plating overhead
In some cases the SMT parts have much shorter leads, so less characteristic inductance and/or capacitance.
I'm not convinced of your statement that SMT ICs are significantly less expensive, just as a beginning design engineer.
Oh well, just my $.02!
Old 10th June 2008, 02:01 AM   #3
IC's are not really less expensive but transistors and especially passive components are substantially cheaper. Plus no holes to drill in the pcb. Not that the extra $2 matters to a diyer.
I just thought a few ns could be cut off rise and fall time (thus dead time) by using surface mount components. I guess its not really worth the trouble.
Old 10th June 2008, 07:53 AM   #4
luka is offline luka  Slovenia
luka's Avatar
Send a message via MSN to luka
Hi
Great thing about SMT is you can put all very close together, this means interference from any noise will be smaller. And like it was said you will save space on board and you don't have to drill as many holes... I like to use both types, SMT and threw hole components, resistors and caps really don't need to be threw hole, but with ICs it is more easy to make board and solder it if you have them threw hole
home page @ http://www.classdaudio.co.cc @ 24/7 all year long
I FEEL SLOVENIA
Surface mount components poorly regarded jwb Parts 52 7th September 2010 04:27 PM
Surface mount components! ungie Swap Meet 12 25th September 2009 02:41 PM
Surface mount components for analogue audio... Yes or no??? Pilbromatic Parts 26 6th August 2009 05:59 AM
Soldering Surface Mount Components Ulas Digital Source 2 14th April 2006 03:38 AM
Page generated in 0.07902 seconds (71.22% PHP - 28.78% MySQL) with 10 queries
