Go Back   Home > Forums > Amplifiers > Class D
Old 10th June 2008, 09:49 PM   #21
luka is offline luka  Slovenia
luka's Avatar
Send a message via MSN to luka
Hi
Having a 250W amp driving a small 16cm speaker will for sure blow it up shortly
I didn't say you *have to* drive them with that, you have gain, turn it down, you can use only 50w if you would like to, but what I am saying amp will have better working condisions if you won't push it to its limit.
I have installed the two amps in my car and, believe me, still 120+120W + 900W on the sub is loud as hell. I don't think I need more power....
Nah that is just right for short say 10-15min car trips to local shops , I have well you can see what I have...it is just right, but note that I am young not old, no offence of course
I don't think I will be building this amp anytime soon, coz I would have to order IRS and I have to many amps already . But if time comes...
home page @ http://www.classdaudio.co.cc @ 24/7 all year long
I FEEL SLOVENIA
Old 29th June 2008, 12:48 PM   #22
mag is offline mag  Switzerland
Default Please help
Hi all,
yesterday I blew up one mosfet of the SMPS (and the related gate driver too...).
The amp was installed in the car for about two weeks without showing any problem.
Yesteray when I switched on my radio I heard a click noise from the amp and then it was dead. The two parallel 20A fuses were exploded.
I noticed that only one side of the push-pull was blown and after having replaced the mosfet, the gate driver and the fuses the amplifer was back alive as before.
I suspect there is a problem with the PSU soft start that creates high inrush current at power up. Is it possible?
I control the SMPS IC trough a timer linked to the remote conection. After 2 seconds that remote is high the Shutdown pin of the SG3526 is released and the SPMS starts.
My suspect is that the shutdown pin does not control the soft start and so the SMPS starts at full duty cycle as soon as the shutdown is released.
Now I have connected the shutdown signal to the reset pin of the SG3526 and it seems to work well.
Can it be the source of the problem? Running an SMPS without soft start can destroy a 180A mosfet? This sounds strange to me.
Thank you
ciao
Old 14th June 2010, 09:50 PM   #23
savu is offline savu  Romania
savu's Avatar
Send a message via MSN to savu Send a message via Yahoo to savu
Originally Posted by mag View Post
Hi all,
Thank you
ciao
Hi Mag,
By using Soft Start pin with the protection circuitry you can do wonders on SG chips.
Just short the SS capacitor with a transistor whenever the protection trips.
The SMPS will stop, then it will restart fron 0 to 50% duty cicle because the soft start capacitor will recharge. during this everithing will start gradualy. If the protection will trip again because let's say you have a short or something, the smps will restart from 0 to 50% duty again. your smps will be protectet and it will allways start from 0 to 50% duty no matter what.
from what i know Shotdown pin doesn't do soft start. so after an unwanted thing that trips the prot it will just start 100% power and the inrush courent will blow fets if they are not big enough to survive.
Best regards,
Savu
1'st rule of chess:
The only way to get smarter is by playing a smarter opponent.
Old 18th June 2010, 07:25 PM   #24
ultra is offline ultra  Greece
ultra's Avatar
motherboard close up
Mag,
this is AMAZING work....Excellent ! your pcb is professional-state of the art
Bravo!
Class-D Amp with IRS2092 mag Class D 185 24th February 2012 03:35 PM
IRS2092 customizable DarkOne Class D 27 26th October 2011 08:16 PM
IRS2092 Amp Design: Please help! Devendra Class D 11 17th March 2011 09:10 AM
IRS2092 Amplifier zox2003 Class D 22 31st August 2009 09:49 PM
Any suggestion for IRS2092 ja2dhc Class D 4 2nd August 2008 10:53 AM
Page generated in 0.10327 seconds (79.24% PHP - 20.76% MySQL) with 11 queries
