| Class D Switching Power Amplifiers and Power D/A conversion |
#21 |
If I were to use only one board for two channels, what is the list for the mods? Many thanks!
#22 |
One more question: what does the 0.68uf cap do in the bridged version?
#23 |
This board already comes with 2 amplifier (single ended), the modifs shown above is to bridge both amp in order to get more power into 8 ohm but then it becomes a mono amplifier. No mods required if you want to use these amp as stereo, except maybe for the output caps which are too small. Change C8 and C21 for 1000uF, 16V or 25Vdc. You don't need to de-solder them just push gently on the caps and they come right off. The 0.68uF (I use a non pol. 1uF) is there to remove some high frequency from the output filter. Hope this helps, Eric |
#24 |
What is the purpose of C3? I can't find it on the schematic, is it a common to both channels Tank Cap that can be Super-Sized?
#25 |
e_fortier:
Many thanks! You mentioned earlier that the gains are set too low. What are the resistors that needed to changed for a higher gain in a bridged version? Thanks again! |
#26 |
Is it possible to use the sure electronics board as headphone amplifier? Has anyone tried? Is it possible after bridging it?
How does it sound? |
#27 |
It would be much more fun and easy to build or buy a Cmoy Mint Tin Amp such as this. You can also roll the chip with these to improve the sound according to you budget..Check E-Bay for Cmoy...
| Which Chip AMP you like most? | dynabok | Chip Amps | 43 | 30th September 2008 08:55 PM |
| 12v Chip | luke691 | Chip Amps | 2 | 10th July 2007 12:31 PM |
| what is a chip amp? | cadbury8 | Chip Amps | 27 | 7th July 2007 08:01 AM |
| Best possible 10W from chip amp | Robert_66 | Chip Amps | 14 | 2nd November 2004 11:43 AM |
| Hot chip! | batkey | Chip Amps | 1 | 14th October 2004 11:54 AM |
| Page generated in 0.09047 seconds (73.26% PHP - 26.74% MySQL) with 11 queries |
