Go Back   Home > Forums > Amplifiers > Class D
Old 9th May 2008, 11:14 PM   #1
Default Using a single channel on a t-amp
I had asked about this a long while back but the project got shelved
I've started again and picked up one of these http://www.richersounds.com/showproduct.php?cda=showproduct&pid=KENS-SX2000
My plan is to build a compact self amplified single speaker for holidays and camping
When I asked before it was suggested that i should use the left and right channels to power the tweeter and driver seperately
But seeing as the t-amp is bridged already would there be a problem in just using a single channel from the amp leaving the other channel open
The reasons for wanting to do this is one simplicity and also it leaves me the option to build a secong speaker and then connect it to the open channel
Old 10th May 2008, 01:05 PM   #2
I want to build a portable guitar amp and have the same question. Can I use one speaker with nothing on the other channel?
If not, can I use some kind of a dummy load?
Thanks,
Carl
Old 10th May 2008, 02:06 PM   #3
Based on discussions on this earlier, there should be no problem doing this, and it is even thought that you might even get a little more power out of the chip if only one channel is running.
Good luck with it.
--Buckapound
Old 11th May 2008, 04:44 PM   #4
Buckapound could you direct me to the discussion on this I've done plenty of searching but cant seem to find anything directly related to this
Old 11th May 2008, 04:44 PM   #5
Thanks for the information.
Carl
irf450 & single channel amp Mordor Solid State 0 17th July 2007 06:12 PM
small single channel car amp regcabdak Solid State 15 16th August 2005 10:32 AM
N-Channel Amp with single OP devices Samuel Jayaraj Solid State 9 31st August 2004 07:57 AM
Page generated in 0.07796 seconds (68.66% PHP - 31.34% MySQL) with 10 queries
