MHz amplifier
MHz amplifier
Old 14th June 2008, 09:28 AM   #131
Pafi is offline Pafi  Hungary
Originally posted by phase_accurate
Take care about what PSU that you use for that test !
Why?
Old 14th June 2008, 10:19 AM   #132
phase_accurate is offline phase_accurate
Evil answer: Try it and you'll see !!!
Nice answer: Because of supply pumping effect !
Charles
Old 14th June 2008, 10:52 AM   #133
Evil answer: think it over!
Nice answer: in this case supply pumping is cancelled by load current, because load current flows from the pumped side of the supply. +10 A load current causes 5 A pumping in negative side, but the 10 A goes thru the load, and landed on negative side, so effective supply current is 5 A in normal direction on both side.
Old 14th June 2008, 12:28 PM   #134
Didn't expect that one to be a bridged type amp !!!!
Charles
Old 14th June 2008, 09:54 PM   #135
Not bridged.
Try it, and you'll see!
Think! There is no load connected to GND. How could supply currents be different? This way the amp is a basic step-down converter.
Old 15th June 2008, 07:18 AM   #136
Ahhhhh !!! I didn't get that they want to connect the load between output and supply rail. In this case of course it doesn't matter.
Charles
MHz amplifierHide this!Advertise here!
Wanted: DIY amplifier builder with experience. I need a 0.7 ohm stable amplifier Audiophilenoob Swap Meet 34 17th May 2005 12:58 AM
Questions about how to decrease the PASS A-40 amplifier into a class AB amplifier. novtango Pass Labs 2 21st October 2002 02:50 AM
