| Class D Switching Power Amplifiers and Power D/A conversion |
#21 |
Hi Pafi, perhaps I was a little too hasty in saying this can't be done. I've been doing some SPICE simulations of a configuration where the post-filter NFB is taken to the summing junction at the input op-amp. It does need a reasonably fast op-amp, (though nothing exotic, I was using an OP37 for the SPICE sims). You have to be careful about the dominant-pole frequency compensation of the op-amp, as well as the NFB network to ensure it will be stable with all expected input signals, as well as oscillating at the desired frequency, but it does give much lower distortion at low frequencies than the standard 'Philips ap-note' UCD circuit.
This configuration described abaove is different from Bruno's schematic in his AES paper, where he shows an input op-amp providing an active pole, but where the switching signal NFB path is still feeding into the comparator. In my simulations I have a single NFB path feeding into a summing junction at the op-amp. The comparator input is connected to the output of the op-amp only. I still don't know if the OTA at the input of the 2092 is fast enough, or whether the required frequency compensation could be applied around it. |
#22 |
the OP37 has a GBW of 63MHz and a open loop gain of 125dB, thus the dominant pole is placed at 35Hz. If I apply the same to the IRS2092 OTA I have the following: OTA Gain=60dB (from datasheet) Small signal BW=9MHz. (from datasheet) Is the small signal BW=GBW or is the -3dB BW in open loop? If it is the GBW the dominant pole will be placed at 9kHz and it is enough to compensate it with some phase shift. Are my thinking correct or not at all? thank you |
#23 |
Ouroboros!
Thank you! I think there is no other thing to do: try it with 2092! They haven't specify open loop transfer of OTA correctly, so we have to measure it, or hope for best, but I dont think there will be a big problem. mag! Small signal BW=GBW, but maybe not with a single pole, however this is the most usual. |
#24 |
Maybe you could try the "simple tweak foir NFB" with this one. This would cost you next to nothing and if it doesn't work as intended it can be changed easily.
The simple tweak for NFB Regards Charles |
#25 |
This is the sort of thing I am looking at for the 2092. (At a very simple simulation level in TINA).
The complex frequency compensation network around the OTA in the IR reference design is required for their pre-filter NFB design, but will not work in a post-filter design. My sim schematic shows a simple C-R compensation network across the OTA, which works well, but of course my OTA model is a simple VCCS, with feedback to set the maximum gain at 60dB, and a single pole roll-of. Might be a starting point for others though. |
#26 |
What you try to do is a very simple case of what is called an NTF (=node transition filter) by Hawksford:
http://www.essex.ac.uk/dces/research...20feedback.pdf Regards Charles |
#27 |
Does any one know where I can get the Simulation library for IRS2092 and send to me?Thanks
Email:anshfe@hotmail.com |
#28 |
can anybody give me some design to build a amplifier using ir2110....have some problems in designing....
| Class-D Amp with IRS2092 | mag | Class D | 185 | 24th February 2012 03:35 PM |
| IRS2092 Amp Design: Please help! | Devendra | Class D | 11 | 17th March 2011 09:10 AM |
| Another amp with IRS2092 | mag | Class D | 23 | 18th June 2010 07:25 PM |
| IRS2092 Amplifier | zox2003 | Class D | 22 | 31st August 2009 09:49 PM |
| Any suggestion for IRS2092 | ja2dhc | Class D | 4 | 2nd August 2008 10:53 AM |
| Page generated in 0.08745 seconds (82.89% PHP - 17.11% MySQL) with 11 queries |
