| Class D Switching Power Amplifiers and Power D/A conversion |
#31 |
Current source you can see at my site.
TAS5706 only see written value, don't care where it comes from. (volume or IR remote or encoder)
#32 |
Panel arrived, now she lives in nice house
![]() This enclosure is only a little bit larger than CD. Hi res photos were posted to my web. I forgot to order RCA terminal
#33 |
Listening with Ni-CD battery. (7.2x2=14.4V)
Very nice More detailed and little bit powerful. I recommend RC Ni-CD or Ni-MH ex, (http://www.radioshack.com/product/in...ductId=2147160) for any Audio battery, by their low internal resistance, and high output current. This small system(Pana CD, TAS5706, QUAD L-ite) sounds {maybe} better than (Pioneer Elite Univ-TacT S2150-QUAD 22L) I had before. I can dive into notation one by one so analytical, base beats my stomach. |
#34 |
Banned
I knew you'd like battery power even on an amp with reasonably good PSRR - more dynamic and quieter - I found the same on the Panasonic SA-XR57 with TAS5076 & TAS5182 which is non-feedback & zero PSRR!
The great thing about these amps is their efficiency & the ability to use batteries - I have a 12V SLA 7aH battery permananently on, powering the output stage (7 * 100W) for 48 hours & no drop in battery output voltage |
#35 |
Koon.
Are you using the EVM controller board (MC57xx) and the TI control software to control setup and registers of the 5706? BTW regaring battery discussions: I am running my Tripath 2020 currently with a Northstar NSB90 battery. It comes with 2mR resistance and it is very fast compared to other batteries. Any smaller size car batteries ( >25mR) gave worse results. Cheers
::: Squeezebox Touch Toolbox 3.0 and more ::: by soundcheck |
#36 |
Hi
How much was that battery, coz here are pretty damn expensive, few 100€, but for that you get battery that can give high current few 100A without much drop of voltage |
#37 |
Yep. They are expensive. I paid 180€ a piece 2 years back.
I got two of them: One for my DAC and one for my Amp. 1. I don't want to start reloading batteries everytime I heat up my rig. The voltage stays rocksolid while playing. 2. Reload cycles degrade ( battery gets higher resistance) your battery over time, which means that small batteries will degrade much faster. 3. Absolute NoNo for low quality batteries or old/used batteries. Have a look a the car audio scene. Perhaps you find similar less expensive types of batteries nowadays. Cheers
#38 |
Banned
By Paralleling a low impedance capacitor to a battery do we not achieve a low impedance load anyway? So is there a need for such a low impedance battery?
#39 | |
I wrote PIC18F source code by myself. http://koonlab.com/TAS5706/Main_01.c.txt NSB90 looks great. huge battery has lower resistance(paralleled internally/chemically). Maybe some difference between Pb based battery and Ni based battery by chemical reaction speed and energy. Now I can recommend Ni-MH (For Radio Control Toys) by it's peak power. |
#40 | |
I was just wondering how to get a connection to the chip to set the registers? My understanding was , to compile your source code on the PC. Running the programme on the PC would set the registers via -- whatever Interface!?. How does the PC connects to the board? You need to understand that - I havn't done hardware programming until know. Cheers
| Full Digital / CrossOver / Multi Amplifier integrated | KOON3876 | Class D | 67 | 18th November 2008 10:05 PM |
| Simple, SIMPLE Digital volume control | -_nando-_ | Digital Source | 5 | 21st December 2006 01:20 PM |
| Tube Output Full digital Amplifier | KOON3876 | Class D | 8 | 14th December 2006 05:54 PM |
| No Full Stereo Seperation ..???? | xitronics | Everything Else | 2 | 7th July 2005 09:25 AM |
| Page generated in 0.11523 seconds (78.18% PHP - 21.82% MySQL) with 11 queries |
