| Class D Switching Power Amplifiers and Power D/A conversion |
#21 | |
Current code (only A/D volume voltage, write to register) works enough. and it will not improve sound quality, just a gimmick. The only problem using carbon cheap volume is, people has "fantasy" that carbon pot volume control spoils signal quality. Of course TASxxxx is not effected by volume controler. no signal pass through pot. TacT's volume control is marketing issue. anyway PIC18F1320 has enough available pins, cheap, simple and C programmable. So if you refer my design, you can add Optical rotary volume control. |
#22 |
Front / Rear panel was ordered. estimated arrival = Apr 14.
I'm using http://www.frontpanelexpress.com/ Enclosure is Hammond 1455Q1601, for 120mm / 160mm sized board. I like this kind of enclosure. |
#23 | |
-Tor |
#24 | |
I don't feel all DIY amplifier should have huge trans, capacitor inside, especially current class-D. (of course also I was making kind of huge chassi amp several years ago...) by separating PSU and amplifier, (a) Like expensive DAC or preamp, power supply noise separation (b) free selection, from AC adapter, Lab DC, battery, eco solar power, hand cranking generator. (c) compact and cheap. (d) easy to build enclosure. there are many pros. and for Lab DC supply, they are safe, low-noise, reliable, accurate. I love them, more than my handmade .
#25 |
Full digital amplifier with digital input such as I2S or SPDIF is excellent choice for natural sound because it bypass DAC, Preamp and Power Amp
But the power of this chip TI is very low: 20W Which are others solutions for full digital amplifier??? |
#26 | |
This one also uses TI chips, but different ones where you can use different amplifier modules. Koon3876 also has another digital amplifier project called tas-4i. Just check his homepage, http://koonlab.com.
-Tor |
#27 |
I think one other solution:
We can use this chip for Preamp full digital what accept I2S or SPDIF input of CD transport. This Preamp digital have analog ouput (RCA) or analog ouput balanced (XLR) and we can use Power amp class D or anything for one big system Is it OK? |
#28 | |
-Tor |
#29 |
20W is enough power to make your neighbor
MAD.you can search TAS5261, for high power. |
#30 | |
-Tor |
| Full Digital / CrossOver / Multi Amplifier integrated | KOON3876 | Class D | 67 | 18th November 2008 11:05 PM |
| Simple, SIMPLE Digital volume control | -_nando-_ | Digital Source | 5 | 21st December 2006 02:20 PM |
| Tube Output Full digital Amplifier | KOON3876 | Class D | 8 | 14th December 2006 06:54 PM |
| No Full Stereo Seperation ..???? | xitronics | Everything Else | 2 | 7th July 2005 10:25 AM |
| Page generated in 0.12677 seconds (79.77% PHP - 20.23% MySQL) with 11 queries |
