| Class D Switching Power Amplifiers and Power D/A conversion |
#11 |
You seem to be on a roll here.
You believe your TAS4i sounds better, might it be because it has better jitter suppression, or just due to the output stage being different? How about adding a USB audio input in addition to spdif, or use a SRC4392 as you suggested? Also, how about adding a digital volume pot, should be easy to do with some PIC code?
-Tor |
#12 | |
(a) single channel, TAS-4i (TAS5518+TAS5142) (b) TAS5706 ... and I'm not sure I can pass blindfolded test. TAS5706 is worthy adversary with LINN Acurate212. (a) pros: Power supply voltage control. (b) pros: closed loop. newer design? TAS5706 board has external I2S input, so if I have time I can try something other than CS8416. Last night I posted initial version PIC source code, with volume control and input selection, to my website. |
#13 |
Banned
Fantastic work Koon,
I'd be very interested in how the I2S input sounds - supposedly cleaner/sharper/clearer than SPDIF Both this & USB input could be achieved with PCM2706/7 USB chip Are you using the same variable PS vol control as used on the TAS-4i? Any idea of offering a group buy of boards when project is finished? This would give something back to you for all the work you are putting in & allow interested (but not as competent as you ) DIYers, like myself, to build something similar! Edit: I'm currently modding the guts out of a Panasonic SA-XR57 multichannel amp based on the TAS5076/TAS5182 Equibit chips. Would love to build one of your TAS5706 amps as a reference to compare against & as a great 2 channel amp! Panasonic class D amps |
#14 | |
TAS5706 does not require variable voltage, it takes 10-26V range fixed. Now I'm using $199 Lab DC supply, 18V/3A, as 12V ps. I will try to connect I2S later, from my SD card player, and USB I2S device. ...By my SD card player, I can try whole DIY full digital, no AC, no motor audio system ![]() For group buy,, just a while until I order box & satisfied for inspection. I have 2 boards so I can send 1 to someone. Then I need someone who could (1) re-inspect. at least measure THD/N, temparature, waveform. (2) re-make. order sample board / parts / assemble / listen. by these step you can think this amp is reproductive. (3) manage group buy. too much job for me. |
#15 |
Banned
Hi Koon,
I would be interested in the spare board if I pay you + shipping - I'll PM you. I have a 100MHz osc but haven't used it yet - I'd have to get up to speed in using it to do some measures but I'm willing. Edit: I can see this amp being very popular to the DIY community so a group buy will probably be very appreciated! |
#16 |
Hi jkeny
don't be so upset... this amp's birthday is just 1 week ago. I have parts for spare board, so initial tester will receive completed one, at free. no money required but... I hope initial tester can, measure THD/N with some frequency / output watt look wavesforms around circuits, and judge against datasheet measure thermal temparature at high watt usage re-program PIC when I updated firmware point out improvement on schematic / board it will take about 1-2 weeks until I get enclosure and panel, misc parts, listen many CDs, measure around. |
#17 |
I posted THD+N result to my site,
1kHz 4W < 0.1%. (please see site for detail) good point is very low 3rd distortion. >jkeny anyway please wait until I finish 2nd board and enclosure. |
#18 | |
Could you consider adding a digital volume pot to the board?
-Tor |
#19 | |
TAS5706 contains digital volume and I'm controling it by PIC. just writing volume value to TAS5706 0x07 register. |
#20 | |
Each clockwise click would generate an up impulse, and counter-clockwise would generate a down impulse. The PIC code could simply update a counter and write the register. This is similar to how the volume wheel on a tact M2150 works. A bit more detailed: http://www.circuitcellar.com/library...52/2303017.pdf A thread with some info here: PGA2310 Digital Volume Control
-Tor |
| Full Digital / CrossOver / Multi Amplifier integrated | KOON3876 | Class D | 67 | 18th November 2008 11:05 PM |
| Simple, SIMPLE Digital volume control | -_nando-_ | Digital Source | 5 | 21st December 2006 02:20 PM |
| Tube Output Full digital Amplifier | KOON3876 | Class D | 8 | 14th December 2006 06:54 PM |
| No Full Stereo Seperation ..???? | xitronics | Everything Else | 2 | 7th July 2005 10:25 AM |
| Page generated in 0.13435 seconds (81.18% PHP - 18.82% MySQL) with 11 queries |
