TAS5706 simple full digital stereo amplifier
Old 23rd March 2008, 04:27 AM   #1
KOON3876 is offline KOON3876
Default TAS5706 simple full digital stereo amplifier
Now TAS5706 amplifier is playing great music from small board
I think TAS5706 can be final solution for Stereo Full digital Amplifier for DIY.
please see my website for detail, and hi res photos.
If anyone want to be group by manager, I can provide ExpressPCB CAD data. ( I don't want to be.. )
Old 23rd March 2008, 06:17 AM   #2
TheMG is offline TheMG  Canada
I'm impressed by the fact you managed to etch your own PCB with enough precision for that IC!
What method did you use? I've been using the transparency/light method and it isn't accurate worth a darn.
Old 23rd March 2008, 07:11 AM   #3
luka is offline luka  Slovenia
luka's Avatar
Hi
It can be done, here are 0.5mm with 0.5mm of space and 0.25mm with 0.25mm space
home page @ http://www.classdaudio.tk/ @ 24/7 all year long
I FEEL SLOVENIA
Old 23rd March 2008, 11:28 AM   #4
Pano is offline Pano  United States
Pano's Avatar
Nice work!
Are you using the on chip volume control? Is that working for you?
Take the Speaker Voltage Test!
Old 23rd March 2008, 01:35 PM   #5
iampivot is offline iampivot
Wow you're working hard on this! Impressive!
A question; does using SMD components provide advantages concerning RF? I'd assume that with a low density PCB like this it would have been possible to make use of larger sized resistors, which would make it a bit more accessible for DIY'ers?
Wouldn't it make sense to add more ground plane areas on the top side of the PCB, in addition to the bottom?
Also, what kind of power supply would you recommend? A 12v STEPS setup? What's the maximum current draw?
-Tor
Old 23rd March 2008, 02:38 PM   #6
This is made by ExpressPCB, I'm not etching for these years. (messy chemical, drilling...)
Yes on chip digital volume control works fine, than Apogee DDXi.
Originally posted by iampivot
does using SMD components provide advantages?
more ground plane areas on the top side of the PCB?
Soldering 0805 is not difficult, and it can provide small footprint / without hall, wireing freedom / cheaper / small storage in my desk.
ground plane on the top works nice at 4 layer board, but small meaning for 2 layer.
Power supply can be 12V, from generic wall adapter to Lab DC power, maximum about 2A. Or you can use Battery, Or if you need more power, you can supply up to 24V.
I'm using small DC Lab power supply, spec 18V/3A. for desktop usage, TAS5706 uses 11V / 100mA.
Old 23rd March 2008, 06:04 PM   #7
Ah, I thought PCBExpress was the software you used. That's what I get for not looking things up.
Old 24th March 2008, 12:08 AM   #8
Found the specs for the TAS5706 here; http://focus.ti.com/docs/prod/folder...t/tas5706.html
Datasheet; http://datasheet.digchip.com/477/477-48390-TAS5706.pdf
And a cheesy little video: http://www.revver.com/video/705245/h...ifier-from-ti/ (apparently it's "optimized for hdtvs and media docking stations".)
Can your design take 18v regulated in order to deliver the maximum 20w output?
-Tor
Old 24th March 2008, 12:57 AM   #9
speakerguy79 is offline speakerguy79  United States
Have you tried using an FM radio anywhere near it?
Old 24th March 2008, 03:42 AM   #10
Yes that's why 5V regulator is switching. no overheating by high supply voltage. you need heat sink for high power.
no noise. but I didn't try AM radio, see datasheet, there are AM interference related register setting.
TAS5706 simple full digital stereo amplifierHide this!Advertise here!
Full Digital / CrossOver / Multi Amplifier integrated KOON3876 Class D 71 21st November 2014 11:56 AM
Simple, SIMPLE Digital volume control -_nando-_ Digital Source 5 21st December 2006 01:20 PM
Tube Output Full digital Amplifier KOON3876 Class D 8 14th December 2006 05:54 PM
No Full Stereo Seperation ..???? xitronics Everything Else 2 7th July 2005 09:25 AM
