Go Back   Home > Forums > Amplifiers > Class D
Old 28th June 2008, 03:48 PM   #71
ChuckT,
There is an IC on Poppulse (near the signal input jumpers) marked 62429. Is this a 'serial data control dual electronic volume' electronic volume control chip?
I swapped the LM4562 with a OPA2107, slight improvement in bass but it is still lacking. I put LM4562 in a DAC707 with the Trends as the amp, and since the Trends has no op-amp, I suppose I was listening to the LM4562 'directly.' Sounds awesome, with very good bass too. The OPA2107 on the DAC707 was a bit more bass for my speakers. Maybe better with my other smaller speakers.
I suppose the Poppulse has too many circuits and the bass could be attenuated by the volume control unit?
Old 28th June 2008, 04:34 PM   #72
Originally posted by RaZmaTaZ
ChuckT,
Yes, check link.
http://documentation.renesas.com/eng..._m62429pds.pdf
The LM4562 is a very good opamp.
Had a talk to Wu of the PopPulse shop, he said the lm4562 sounds better with higher gain, he went to 8x, current setup is 2x, I believe.
Old 29th June 2008, 01:53 PM   #73
Originally posted by ChuckT
Yes, check link.
Thanks ChuckT. Err so do I replace the lm4562 with an op-amp that will do better at 2x gain? Or do I find out how to increase the gain to 8x? Replace a resistor maybe?
Old 30th June 2008, 01:06 PM   #74
Increase the feedback resistor to increase gain for each channel.
If u don't know which one, you'll have to do a little research of your own. They connect the output pin and the negative input pin.
In addition, there might be improvement if you put a nice 0.1uf cap across the +/- power pins.
Old 4th July 2008, 09:08 AM   #75
If u bypass the opamp stage LM4562, I suggest lower the feedback resistor from 20k to 10~15k to increase the gain of the TA2022.
In fact, I wonder if it is a good idea to increase the gain of TA2022 anyways, because the tripath uses an internal opamp and PopPulse set it at unity gain for the opamp.
I think some opamp do not sound good with unity gain.
I lower the feedback resistor from 20K to 10K and it seems the bass and detail improve a bit, could be my imagination.
Old 4th July 2008, 09:48 AM   #76
Ops, that should be lower the INPUT resistor, not feedback.
Old 7th July 2008, 03:27 PM   #77
Ok, so you suggest to bypass the LM4562 and drop the input resistor to 10k? What is the effect on the volume of the system? As in what would be the drop in db level? For example, if I usually listen to the Poppulse at -36db, would the same level of loudness without the LM4562 be at -33db or -30db?
Old 8th July 2008, 12:10 AM   #78
Originally posted by panomaniac
This is an interesting subject. High or Low damping factor? I like the high damping factor, but I tend to use "loose" speakers. A lot of guys here don't like the sound of big caps in the PSU. I suppose the lower damping gives stiff speakers (e.g. Fostex, Lowther, etc.) a little more "swing".
I was talking to a speaker designer buddy last night about this. He says that with stiff speakers and/or low listening levels - low damping factor sounds better.High damping and stiff drivers with a low power amp can equal NO bass. Tube amps usually have a low damping factor, thus the "musicality".
Not until you get a very powerfull amp with high damping does the bass come back.
Bob Carver, of Carver Amps, used to claim he could imitate the sound of any amp just by changing the damping factor of his amps.
For me, the large PSU sounds better, not just tighter bass, but better dynamics and a wider soundstage. But that might not be the case with some speakers.
I'd like to know what you find in your PSU experiments.
And in another post:
Right, seems to be speaker dependant. And a matter of taste, too. Big cap = tight dry bass. Small cap = loose, more generous bass.
Hi Chuck and Razmataz, just looked again into this thread and read this interesting quote from panomaniac (thanks chuck) and want to add my expereciences testing the Poppulse and another Tripath Amp from Silverstone (Model EB02).
I have the possibility to hear with several speakers and I found something interesting:
Beside the two Tripath I own a very potencial and well known Power Amp from older days - the Exposure Super 8 - one of the better and expensive ones of class A/B. Following Speaker - Amp Combination was tested by me:
B & W Preference 6 with Exposure >>> Too much bass full filled in room - I thought the Exposure was raping the speakers :-). It might also depend on the B & Ws because much speakers of this brand are well known for their pronounced upper bass. Not a good combination - IMO
Allison Al-105 with Exposure >>> Great Combination - well balanced in all frequencies. Super rhythmic sound. Here you could really enjoy the quality of exposure
Allison Al-105 with Poppulse >>> a slight flat - but a quick and a good kick bass. Soundstage is wide and Mids are present.
Allison Al-105 with Silverstone>>> after played warm the soundstage was a bit more detailed and full compared to combination above. Mellow but a bit soft bass. I prefered this combination especially on lower volume. Great and colourful detailed mids.
But the Silverstone is limited in power compared to Poppulse.
Allison CD 6 with Poppulse Great combination. Full , colourful sound. Well balanced.
JmLab Profil 77 with Poppulse Also fine combination and better than with the Al-105. Not a slight flat bass like with the Al-105.
I wished the Silverstone (with Tripath TA2021B) had a bit more power. This amp really surprized me positiv way with the Allison Al-105.
So guys what should I say: I am full busy nowadys with Class D Amps and still looking forward to receive the next ordered Class D: Nuforce Icon (No Tripath - a different chip). Seems to be a little wonder Will report you soon ... here or in a separate thread.
Old 8th July 2008, 07:22 AM   #79
Just discover a good tweak relating to the internal opamp of TA2022
The decoupling of the two 5V use by the internal opamp is poor. The power supply has 7815, resistor to drop voltage, ferrite, then to a 7805 that supplies both 5V for TA2022 and the digital vol chip.
My tweak is remove the 0.1uf ceramic next to 7805 and next to 5V pins. And directly put a small cap on each of the two 5V pins.
I use the Blackgate hi-q 47uf/6.3V and the result is better bass and better mid. Need to burn in for long time.
Old 9th July 2008, 12:20 PM   #80
Quantom is offline Quantom  Singapore
Just curious. On the stock PopPulse (yes I really mean stock, haha), does anyone get a trace of static after the unit warms up and "clicks" into activation? I get hissing on my model, and I'm wondering if anyone has a clue how to resolve it. It shouldn't be a power problem, as I've tried a few power points and they all seem to have the same issue.
IR Remote Protocols - Other Remote Info PB2 Everything Else 17 7th June 2010 09:25 AM
Remote volume control for existing remote? theAnonymous1 Parts 7 6th August 2007 08:22 AM
Remote volume - existing remote Stuey Chip Amps 16 25th August 2006 11:44 PM
Remote remote volume simon dart Parts 3 7th November 2004 10:00 PM
Page generated in 0.14456 seconds (84.38% PHP - 15.62% MySQL) with 11 queries
