Go Back   Home > Forums > Amplifiers > Class D
Old 11th April 2008, 07:51 AM   #11
Ok Chuck. Thanks for the advice. I shall change change the fuse and try and get those Vishay caps (6 of 'em huh?)
Meantime, I shall wait for my newly ordered Winsome (and probably order the Value Mod Trends from Audiomagus next week too.) And then will attempt the mods on the Poppulse.
This my new do-all strategy. What the heck? I ain't gonna take any money with me when I die, so let's live a little and learn a whole lot more in the process.
Old 11th April 2008, 10:35 AM   #12
Hi Raz, would be aprechiated if you tell us more after modyfied your amp.
Old 14th April 2008, 01:00 PM   #13
The 6 coupling caps are red Elna BP 10uf/16v in the pic.
Old 15th April 2008, 02:58 AM   #14
Chuck
Alright! Thanks. Will try it out.
Old 15th April 2008, 03:49 AM   #15
Thanks chuck for the pic. Much appreciated. This will help.
Maybe another question: I tried Bi-amping with y-cables.
Worked fine till the buzzing which comes out from one amp. I think
this depends on the voltage transformator. Can I compensate it anyway myself ? I think this doesnt have an effect on the sound or ?
Me myself couldnt hear it out in fact.
Old 15th April 2008, 03:16 PM   #16
The biggest bottleneck for the poppulse is the 6 coupling e-caps. Replace those and you'll be on another level. I suggest Visay MKT1822 3.3uf (63v or 100v) will be an excellent choice.
Check the fuse, if it is 1A, replace it with 4~5A.
The decoupling for the poppulse is not the best. And for the life of me, I don't know why there are no regulation of the +/- 35v and that the e-cap is removed just next to the chip. There are only an Elna 4700uf + 1 smd all the way to the ta2022.
So add a nice > 200uF/35V cap back into that empty cap space next to the chip.
There are a lot more mods that can be done. Later.
I have play with the TA2024 chips before and in my opinion the TA2022 sound better in my system (low efficiency speaker)
I hope this Picture (attachment) works, I am not sure. If not please can anyone explain me how to do ??
Just wanted to show a pic of an vishay cap - maybe chuckT could tell me if they look like these ones because one with 3,3 uF I couldnt find here:
http://de.farnell.com/jsp/search/bro...=gensearch_002|gensearch_002&Ntt=vishay|mkt1822&Ntx=&_requestid= 121115
Can anyone at least submit that they are yellowcoloured and are squared and not round ??
Old 16th April 2008, 10:10 AM   #17
Yes, MKT1822 under the ERO brand before Vishay buy them out.
Mine are green with the Vishay label, I don't know if they will be a difference in sound for the old and new.
I got them from Farnell too, so I think you'll get the green one too.
BTW, if u don't need a lot of gain, it may be possible to bypass the opamp and connect directly the M62429 output to the TA2022 input cap. I think inside the M62429 has opamp out already.
If u don't know what I am talking about, just ignore this.
Also order a couple of Rubycon ZL 470uf/35V to put into the empty 220uf/35V cap space next to the ta2022.
There is a lot more u can do... no time....
Old 16th April 2008, 10:13 AM   #18
Don't know.
So how does bi-amp sound? Certain much improve channel separation...
Old 16th April 2008, 03:37 PM   #19
Don't know.
Hi, just didnt hear long time, but you can hear the increase of performance. Sound more relaxed and more control.
One remotecontrol works for both but sometimes the other one gets +1 - +3 more dB than the other. Better is to steer volume step by step.
Or they have to play together a while. Like dancepartners you know
Hadnt ever thougt that you can mod the this amp so much. I you really sure that we listen another level ? I mean "higher" level
Old 26th April 2008, 05:15 PM   #20
Dealer,
Did you manage to get the caps from Farnell? I'm having problems getting the right specs. I thought I found it last week but now I only see mkt 1822 with 2.2uf/63v or 10uf/100v. Can't seem to find them on RS as well, they too have 2.2uf or 10uf. But RS has the 3.3uf in 250v
ChuckT, will the 10uf/100v be ok? Or the 3.3uf 250v?
IR Remote Protocols - Other Remote Info PB2 Everything Else 17 7th June 2010 10:25 AM
Remote volume control for existing remote? theAnonymous1 Parts 7 6th August 2007 09:22 AM
Remote volume - existing remote Stuey Chip Amps 16 26th August 2006 12:44 AM
Remote remote volume simon dart Parts 3 7th November 2004 11:00 PM
Page generated in 0.14691 seconds (76.74% PHP - 23.26% MySQL) with 11 queries
