PopPulse T-amp with Remote - modding
Old 26th July 2012, 01:05 AM   #101
Fossil is offline Fossil  Singapore
wondering if anyone still holding on to this amp after 3(?) yrs.
recently I got my hands on smsl ta2020 (sa-s1). Even with a 12V 2A smps, I was taken aback by the performance of this small little amp. Really amazed at how much details and separation this cheap amp can produce! Wished I had try it 5 yrs ago! Since the casing is o small, I added additional reservoir caps between externally between the SMPS and the ap. Seemed to have improved another notch.
Anyway, it so happened that I saw a Poppulse available after that and so I grabbed it since t's an upsized tripath.
However, I would say that it's a bit disappointing as it seems to be lacking in the level of resolution. I guess it has to do with the elna coupling caps repeated throughout this thread.
Since it's still a new acquisition, I just don't feel like doing too much. So I was wondering if I should just solder a wire to bypass the elna in the front stages but retain those at the input of the TA2022. Perhaps I could also parallel a small PP cap with the TA2022's elna on the underside of the PCB.
BTW, anyone did anything beyond what was mentioned here?
Old 27th July 2012, 02:20 AM   #102
I shorted and bypass the elna into the vol control and the opamp and the amp went into 'protection mode'.
Even when I bypass those for the opamp, it went into 'protection' after a few minutes.
So in the end I just bypass all the elna with 0.1uf I have on hand.
Was happy it's working again....so it'll be a while before I open the box
PopPulse T-amp with Remote - moddingHide this!Advertise here!
IR Remote Protocols - Other Remote Info PB2 Everything Else 17 7th June 2010 09:25 AM
Remote volume control for existing remote? theAnonymous1 Parts 7 6th August 2007 08:22 AM
Remote volume - existing remote Stuey Chip Amps 16 25th August 2006 11:44 PM
Remote remote volume simon dart Parts 3 7th November 2004 10:00 PM
Copyright ©1999-2017 diyAudio
