Complete noob needs help
Old 7th March 2008, 07:59 PM   #1
tstarn06 is offline tstarn06  United States
Default Complete noob needs help
Sorry for the basic question, but I own three T-Amps (Sonic impact), two originals and one V2. I just bought the V2 and already, in 3 days, broke one of the speaker clips. I just touched it, and the spring flew out. I was trying to insert some Anticable speaker wire into it, and boom!
Anyway, I figured I might use the opportunity to try my first DIY project, basically taking the T-Amp out of its cheap housing and into a more robust container, adding real speaker connections, a better volume control (pot, right?). You can see, I am a real beginner.
Can I do this? Is there anywhere on diyAudio with this already outlined?
Any help would be greatly appreciated.
Old 7th March 2008, 08:02 PM   #2
Marsfrogie is offline Marsfrogie  United States
Check these first.
www.michael.mardis.com
And
http://www.diyaudio.com/wiki/index.p...+Amplification
Old 7th March 2008, 08:11 PM   #3
Buckapound is offline Buckapound  United States
And this one:
http://www.diyaudio.com/forums/showt...threadid=50870
There are several threads on this forum, about different versions of the T-Amp. They're pretty easy to pick out of a list of the Class-D topics here. Also check the FAQ, as there's some good background and links there.
Enjoy yourself. These little amps are a lot of fun and a great way to get your feet wet in DIY audio--and amaze and astound your friends. Don't be afraid to tackle the parts modifications, especially the capacitor upgrades, which are detailed in these threads and on Michael Mardis' site.
--Buckapound
Old 9th March 2008, 01:39 AM   #4
If you decide to mod one yourself, make sure you have a fine tip soldering iron with temperature control. You don't want to burn the surface mount pads. Do everything in your control to only use short bursts of heat on the board. I had the mishap of burning a through hole pad and had to reroute wires to another area of the board.
Old 10th March 2008, 12:16 AM   #5
Thanks everyone. I hope I don't destroy my T-Amp. Seems to intimidating. But I will take it slow.
Old 10th March 2008, 09:03 AM   #6
audio1st is offline audio1st  United Kingdom
audio1st's Avatar
Hi tstarn06,
If you are worried about messing up your board and would be happier just re-casing, then I have attached the diagram for that.......
You could leave the original speaker leads and power leads attached to the board to keep things simple.
You can always do the other mods later when you feel more confident.
PS, the boards are a lot smaller in the flesh than they look on the PC..Good Luck..
Complete noob needs helpHide this!Advertise here!
complete noob question beauistheman Chip Amps 19 10th August 2009 06:37 PM
Complete noob to all of this, help to my feet? jesuslovesyou Subwoofers 5 4th September 2007 01:51 PM
almost complete rv1890 Multi-Way 6 21st February 2006 06:28 PM
Amp or Pre-amp Complete kit fcel Solid State 2 19th September 2001 01:53 PM
Copyright ©1999-2017 diyAudio
