Please help, I attempted to mod a TAmp and the fuse blew.
Old 1st March 2008, 08:20 AM   #1
Marsfrogie is offline Marsfrogie  United States
Default Please help, I attempted to mod a TAmp and the fuse blew.
Hello. I just got done fiddling around with my TAmp in an attempt to mod it. When I plugged it in my power supply blipped yellow (load) and popped the 3A inline fuse. This is a Super TAmp.
Here is what I did.
Removed C1 C2 R1 R2 R3 R4
Bridged the place where R1 and R2 used to be.
Installed Solen 2.2 micro farad caps in place of the electrolytics.
Installed a 10000 micro farad cap where the power leads go into the board. (Could this cause the fuse to blow?)
Replaced C8 with a Panasonic FM 2200 micro farad cap
Replaced C10 with a 1000 micro farad Panasonic FM. I put the negative to the chip prong.
Removed L8 L9 L10 L11 and bridged the connections where they used to be.
Removed C25 and C26, Removed R20 and R22
Added 0.1 micro farad caps directly to the output leads. (I could not find a polarity on these so I guessed)
Added a 100 micro farad electrolytic panasonic FM cap to the back of the power connector coming into the box. Negative to negative, positive to positive.
Replaced the 470 micro farad caps that were on board.
Any ideas? Thanks for any help.
Old 1st March 2008, 08:35 AM   #2
Netlist is offline Netlist  Belgium
diyAudio Moderator Emeritus
Netlist's Avatar
I don't know the T-Amp but as a rule of thumb, reverting it to its original state and doing mods one by one is a better way to go.
A schematic would help too.
/Hugo
Old 1st March 2008, 09:50 AM   #3
audio1st is offline audio1st  United Kingdom
audio1st's Avatar
I would think your problem is C10, shouldn't this be 1uF (+pos to chip pin 36)?
Old 1st March 2008, 03:56 PM   #4
http://www.michael.mardis.com/sonic/start.html
That is a link to michael mardis's schematic.
C10 is originally 330 micro farad and is a power tank. Perhaps it is backwards. Can someone take a look at that schematic and tell me?
Old 1st March 2008, 04:36 PM   #5
Netlist's Avatar
If the fuse pops instantly, I'd go for a short circuit between VDD and ground somewhere. Check with Ohm meter.
A reversed electrolyte would explode after a few minutes and then perhaps pop the fuse.
/Hugo
Old 1st March 2008, 04:51 PM   #6
audio1st's Avatar
That link is to the basic T Amp and not the Super T..
See here...
Old 1st March 2008, 05:05 PM   #7
Sorry I put up the wrong link. That is the schematic that I have been using.
Old 1st March 2008, 05:07 PM   #8
audio1st's Avatar
And is this C10?
Old 1st March 2008, 05:17 PM   #9
Yes that is C10, but I have board version B so the stuff around it is slightly different. I put the plus side of the cap to the left side of that picture and the minus side to Cpump pin.
Old 1st March 2008, 05:20 PM   #10
audio1st's Avatar
It should be a 1uF ceramic...
Please help, I attempted to mod a TAmp and the fuse blew.Hide this!Advertise here!
Has anyone attempted this before? onform Vendor's Bazaar 0 31st August 2008 06:33 PM
OT: DIY Attempted Theft Stories rjbond3rd Full Range 27 11th March 2008 09:11 AM
Fuse blew markiemrboo Chip Amps 30 21st November 2006 05:40 PM
Has anyone attempted to build high end studio monitors? Optical Multi-Way 14 9th September 2004 04:00 AM
Copyright ©1999-2017 diyAudio
