Stupid Class D Questions
Old 19th February 2008, 03:24 PM   #1
Mat_89 is offline Mat_89  United Kingdom
Default Stupid Class D Questions
Hey.
Sorry, i have been reading about class d amps but i am a lil confussed so im going to ask some very stupid noobish questions.
Firstly, is the power of the amp just dependant on the power supplied to the MOSFETs and the gain in the same way as a transistor?
Secondly, i am under the understanding that in a basic amp that one of the MOSFETs is on while the other is off? how is this possible when they share the same input?
Attached image is diagram of samples ive been learning from
Mat
Old 19th February 2008, 03:39 PM   #2
richie00boy is offline richie00boy  United Kingdom
Did it Himself
richie00boy's Avatar
The power is dependent on the voltage the amp can output into a given load impedance, which will depend on the current capacity of the supply and the voltage rails. Obviously the current and voltage ratings of the output devices used must be able to take the conditions (safe operating area).
Gain is relevant only to determine for what input signal level the output voltage will (try to) be.
Yes only one output device is on at any one time, otherwise there would be a huge short circuit across the power supply. They don't quite share the same input, they will either be driven of opposite polarity signals or some kind of inverter before one of the devices, or in the case of the figure you attached one is n-channel and one is p-channel so they work in opposite polarity.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, modules and more.
Stupid Class D QuestionsHide this!Advertise here!
A stupid questions about fuse, please help goldkenn Class D 8 30th September 2008 09:23 AM
Stupid PAS-2 Pot Questions neddyboy Tubes / Valves 5 7th June 2007 12:26 AM
Some simple/stupid audio questions Eric_B_C Everything Else 8 2nd January 2007 11:39 PM
A new (Stupid?) class d idea Tekko Class D 79 5th December 2006 03:01 AM
probably a stupid questions about opamps soundNERD Chip Amps 2 30th March 2004 01:59 AM
Copyright ©1999-2017 diyAudio
