Go Back   Home > Forums > Amplifiers > Class D
Old 17th February 2008, 03:34 PM   #1
diyAudio Moderator Emeritus
Default BCA filter
I try to simulate a simple half bridge LC filter, L=22uH, C=1uF, load=4ohm.
Old 17th February 2008, 03:35 PM   #2
The response is like this
Old 17th February 2008, 03:35 PM   #3
Now I add 2 diodes and 1 extra inductor, to make a BCA output stage.
Old 17th February 2008, 03:38 PM   #4
Why is the response become like this? The peak is about +18.5dB.
What is wrong with my SIM? Changin the values of L or C don't help.
Old 17th February 2008, 04:28 PM   #5
Workhorse's Avatar
Send a message via Yahoo to Workhorse
The Gate drive to both devices in BCA is always in phase and hence the devices conduct simuntaneously!! whereas your diagram shows simple complementary halfbridge, in which device conduction is based on appropriate polarity of signal with respect to channel polarity of device
Also the inductors used in BCA are atleast 220uH not 22uH.
It's a fruitless endeavor to try and educate a fool that rejoices in ignorance
need help wana change 60-Hz twin-T notch filter to 279 Hz filter prorms Solid State 0 9th February 2008 11:38 PM
Can Zaphs notch filter be used without the BSC filter? GuyPanico Full Range 0 21st July 2007 01:27 AM
Just one big filter cap or more smaller filter caps ... beppe61 Power Supplies 2 18th July 2006 05:46 PM
active filter from rod elliot and sub filter questions wuffer Parts 0 2nd October 2005 01:12 PM
chassis-mounted filter or IEC plug filter jarthel Solid State 7 11th March 2002 10:17 AM
Page generated in 0.08624 seconds (69.13% PHP - 30.87% MySQL) with 11 queries
