| Class D Switching Power Amplifiers and Power D/A conversion |
#21 |
out after notch
0.5v/div, 2us |
#22 |
out before notch
1v/div, 1us |
#23 |
out before lc filter
20v/div, 1us, positive |
#24 |
20v/div, 1us, negative |
#25 |
Same white noise.... |
#26 |
Even if i replace floating smps with 2 x 9v bat, still noisy.
Even if i remove inductor from pcb (at about 20cm), noise is still the same... Even if i put a more decoupling caps for vcc (ceramic, mkt, etc) ... Even if i put rc snubbers; scottky antiparalel diodes, adjusting deadtime, etc... still the SAME noise... 6N137? ... i don't know... |
#27 |
Try adding more capacitance to the outputs of the L7805...
I use to feel like the small child in The Emperor's New Clothes tale
#28 |
... tryied...
#29 |
Try increasing and decreasing the value of 6N137 load resistors and also try changing 6N137 LED drive current.
#30 |
diyAudio Moderator Emeritus
Are you using TO247 mosfets? It will have significant capacitance between Drain/flange with ground (if the heatsink is grounded).
You can try putting aluminum oxide insulator (1-1.5mm thick) to lower this capacitance. |
| EL34 Power Stage | AmpBuilder225 | Tubes / Valves | 6 | 16th February 2009 04:39 PM |
| phono stage hiss | woodturner-fran | Tubes / Valves | 6 | 15th April 2008 08:59 PM |
| 2 stage power amp | Leolabs | Solid State | 3 | 29th March 2006 01:48 AM |
| Single Stage power amp. | lumanauw | Solid State | 10 | 2nd April 2004 09:03 AM |
| power output stage | Jennice | Pass Labs | 22 | 19th June 2003 11:59 AM |
