optocoupling power stage - hiss with 6N137
Old 7th February 2008, 03:19 PM   #11
lumanauw is offline lumanauw  Indonesia
diyAudio Moderator Emeritus
lumanauw's Avatar
Send a message via Yahoo to lumanauw
This may be troublesome, but you can try to replace 6N137 with transformer (PulseEng gate driver or something else), to know for sure if it is the optocoupler that is making the noise.
Old 7th February 2008, 03:43 PM   #12
ionutgaga is offline ionutgaga
I'm already ordered HCPL2611 and HCPL0611 (smd version of 2611) used in PowerSoft and Crown comercial PA. But i have to wait a couple of days before i will try to change my 6N137 optocouplers. In the meantime i will try to figure out what other else is the source of the white noise...
Old 7th February 2008, 03:43 PM   #13
lumanauw's Avatar
If you got a soundcard and FFT program, you can iterate the noise problem. If it is audible, then it should show up in fft below 20khz. Try to change something, then look at the fft whether it becomes louder or fainter, or if it is shifting frequency. Then you can try to approximate what is causing the problem.
Old 7th February 2008, 04:05 PM   #14
Thanks lumanauw for your valuable advice!
I will try this maybe tommorow, when i repaired my final stage (i'm abusing a little: +/-130v at 2 ohm, only a few minute, then...)
Old 7th February 2008, 04:26 PM   #15
fredos is offline fredos  Canada
What happen if you replace your 2 floating supply with 9V battery? Be sur to completly diconect floating PSU to avoid coupling inside transformer...If it solve your probleme, try using 2 small separate transformer...Even if you adjust flaoting power supply to same frequency of your amplifier, this do not syncronize them!
Old 8th February 2008, 11:17 AM   #16
Some photos of my prototype (incomplete, only power stage without floating smps...)
Old 8th February 2008, 11:19 AM   #17
and top:
Old 8th February 2008, 01:05 PM   #18
Some measurement. +/-90v, 4 ohm, 10mhz oscilloscope
TC429 out, 2v/div, 0.5uS
Old 8th February 2008, 01:06 PM   #19
-vcc to gnd
1v/div, 1us
Old 8th February 2008, 01:08 PM   #20
+vcc to gnd
1v/div, 1us
optocoupling power stage - hiss with 6N137Hide this!Advertise here!
EL34 Power Stage AmpBuilder225 Tubes / Valves 6 16th February 2009 04:39 PM
phono stage hiss woodturner-fran Tubes / Valves 6 15th April 2008 08:59 PM
2 stage power amp Leolabs Solid State 3 29th March 2006 01:48 AM
Single Stage power amp. lumanauw Solid State 10 2nd April 2004 09:03 AM
power output stage Jennice Pass Labs 22 19th June 2003 11:59 AM
