Go Back   Home > Forums > Amplifiers > Class D
Old 4th February 2008, 06:18 AM   #1
jkeny is offline jkeny  Ireland
Banned
Default Output Inductors
Can anybody say if the apparent closeness of these output inductors could cause problems - mutual inductance?
Old 4th February 2008, 03:49 PM   #2
y8s is offline y8s  United States
y8s's Avatar
Send a message via AIM to y8s Send a message via MSN to y8s Send a message via Yahoo to y8s
toroidal inductors tend to have a pretty tight leash on leakage flux. if you do the 'right hand rule' on them, you'll see that the field (at least in theory) cancels itself out.
so the effect is probably minor.
Old 5th February 2008, 06:55 AM   #3
Ouroboros's Avatar
Even if the flux was 100% contained within the toroid, there would still be a 'virtual' single turn air-cored coil when you wind a toroid as a single winding. You can wind half the toroid and then take the wire diametrically across to the other side and finish winding the other half. (As seen in the better type of inductors on some SMPSUs). This cancels out most of the 'virtual single turn' effect.
(Bruno Putzeys for example stresses this point quite often. I know he frowns upon toroids that are not co-planar to the pcb).
So basically, in your photo, from the mutual coupling point of view, you have a number of single-turn air-cored inductors in line. There will be some coupling but I doubt if it will cause any problem.
Old 5th February 2008, 07:30 AM   #4
Eva is offline Eva  Spain
Eva's Avatar
Send a message via MSN to Eva
Winding toroids in two opposed "runs" as encouraged by some authors does *not* solve the parasitistic turn problem at all. It just produces an eight-shaped dipole. Near field improvement on leakage flux is marginal, except exactly on the perpendicular axis where flux cancellation arises. Furthermore, far field leakage flux in toroids is negligible so no improvement is easily measurable either.
Don't worry that much about these toroids.
I use to feel like the small child in The Emperor's New Clothes tale
Old 8th February 2008, 11:31 AM   #5
ranga is offline ranga  Romania
Would this configuration solve the issue?
if you compute the inductance as 2 series inductors and wind them at 180 degrees they will cancel each other (the fields from each single turn air inductor). Am i right ?
edit: Sorry about my MsPaint skills !!
Shielded or Toroidal Inductors for Class D output filter speakerguy79 Class D 24 10th February 2009 10:33 PM
Class T Output Inductors : Litz or Solid Core? Peteruk Class D 2 8th April 2007 01:03 AM
Dual differential mode inductors in a bridged output lowpass filter BWRX Class D 3 17th November 2005 03:39 PM
SI with AMP3 toroid output inductors BWRX Class D 14 11th July 2005 01:44 PM
Page generated in 0.08870 seconds (69.62% PHP - 30.38% MySQL) with 11 queries
