| Class D Switching Power Amplifiers and Power D/A conversion |
#231 |
Hi All,
After some measurements, I found the reason why one channel oscillating at a lower frequency. The reason is the LM311 itself. Interestingly it is ~100ns slow than the others. And hence replacing it with a new one solve all the problems. Now all the channels running around 400-430kHz. The idling loss for SMPS itself is around 2Ws(none of the channels connected) and the idling loss for two Channels around 5Ws. It looks the channels not fighting to eachother in the sw frequency means. So the amp is fine just now and i am going on to complete it up to final version. I have to build output protection relay board and fit it into the place. Then I can start tests at idle, mid and full power. Chreers |
#232 |
hi, bender i can't open your file, could you sent to my email please:
hari_wibowo_jmb@yahoo.com thankyou verimuch. |
#233 | |
Bender The Specs, and the compact looks like, more than for a DIYers. Thanks for sharing. If your tool can generate BOM with footprints of components. Can I request you to post it here. So that I can check if its available for me to buy and built one for myself. I am very much eager to hear this.
There is always a first time.... |
#234 |
Hi all,
I think there are several questions around and there are many others similar to the amp discussed here. Anyway, I started to do the amp below for a very long time ago. And now it went into a good PCB. The entire PCB is 105um Cu thickness and i had it made from a China manufacturer (hell, it was a difficult process to get them). The photos below are nearly completed amp but, still 3 auxiliary PCB are missing. They will be available soon. I hope you all like it. Best wishes |
#235 |
man, they came out very very good, is it playing yet?
#236 |
#238 |
Looks really good. Is it an isolated smps on the board as well?
#239 |
#240 |
hello Whortless
good job1 i like it) but same question to you.. do U synchronized all your drivers IRS??? how u do it, if yes (sorry for my english) |
| Anyone seen this amp topology before? | BlackUnikorn | Tubes / Valves | 14 | 6th August 2008 08:51 PM |
| cf topology lessons... pls help | JojoD818 | Tubes / Valves | 21 | 30th April 2004 10:04 PM |
