| Class D Switching Power Amplifiers and Power D/A conversion |
#221 |
#222 |
love it!
![]() What about sound quality? Describe.. |
#223 |
#224 | |
#225 | |
I suspect from the output inductor, Ferroxcube TN 26/11-3c20-a113 wound 17sp gives 31uH (remaining 4 of them TN 23/7.5-3c20-a65, 22sp). I measured next channel and they are in same value. However, the next channel do not have same issue. Do you think it is still output impedance/zobel network problem. BR Last edited by Whortless; 14th February 2012 at 05:47 AM. |
#226 |
#227 | ||
Obviously fsw does depend on load impedance in UcD. Quote:
Parasitic feedback is probably magnetic/inductive at this low impedance. |
#228 | |
Thanks |
#229 |
UcD is a phase shift oscillator. If you are trying to use a zobel on it, you are not understanding how and why it works, you are just copying!! (In a creative but not thoughtful way). Note that UcD was developed to avoid zobels on the output!!
On the other hand, anything that changes the phase shift from comparator output node to the feedback node will affect self oscillating frequency. This includes: output capacitor parasitic and layout inductance, loads that don't become high impedance above 20khz (ie: not a speaker), adding a cap with wires (it's a LRC), adding a cap even without wires (it's again a LRC with lower L), adding a RC (which changes phase response of output filter). Getting UcD right requires some RF thinking, the actual frequency response of everything in the power path matters (unlike in clocked amps, triangle wave modulators were invented to cope with "dirty" power stages at the expense of linearity and freq. response).
I use to feel like the small child in The Emperor's New Clothes tale
#230 | |
However, there should be some misunderstanding about Zobel network. Because I did say it is not due to the zobel network. I am not copying someones design (ie. Bender.ru). If i would do so, i would completely copy his desing. The actual thing is Bender.ru and I thought the same thing at same time and I was already desinging the circuit with MAX1016 while he was doing with LM311( Logic is same and if something logical two or more people can think the same thing at same time.). However he posted complete desing on thread and i gave up working on it. Anyways, We agree in some points and disagree in some others. I said the sw frequency of UCD does not depend on load in one of the previous post. However, i did not mean in the understood manner. The sw frequency of UCD does depend on load but not as much as i faced with actually. In my case i kept the inductor same and put an additional C to change the filter response and get higher self osc frequency. This is true logic and as is the case not true always. Hence, the sw frequency of UCD does depend on the Hloop and this is effected by Rlead, Clead, Rin, Rfb and Lout Cout+ propagation delay from input to output. We know that the typical propagation delay of IRS20957s is 90ns and LM311 has an 200ns of response time whereas the original design discrete UCD amp has an 210ns propagation delay. Therefore, one should expect a different sw frequency with the same component values used in discrete design. The interesting thing is the self osc frequency difference between the channels. I am not using %1 tolerence resistors or capacitors. But, one can not expect so much difference from channel to channel. I tried 220,330,470,680,1K and 2.2K for Rlead and believe or not i always get the same sw frequency for the LF oscillating channel, which is around 300kHz. Then i changed Ri from 2K2 to 1K5 and get 330kHz and leave it like this. But, there should be something wrong with this channel because all the others running around 410kHz with the Rfb=22K, Ri=2K2(should be changed into 1K5 to ensure same gain), Rlead=2K2, Clead=220p(outputfilter inductor always same inductance =30uH and the Cout=1u). I also swapt the Lout from another channel and the sw did not changed. Hence, the IRS20957 or LM311 can be the reason or the PCB itself. What can be else? Best wishes. |
| Anyone seen this amp topology before? | BlackUnikorn | Tubes / Valves | 14 | 6th August 2008 08:51 PM |
| cf topology lessons... pls help | JojoD818 | Tubes / Valves | 21 | 30th April 2004 10:04 PM |
| Page generated in 0.13792 seconds (69.48% PHP - 30.52% MySQL) with 11 queries |
