Go Back   Home > Forums > Amplifiers > Class D
Old 23rd January 2008, 07:25 PM   #1
Bgt is offline Bgt  Netherlands
Default MCD-255 amp
Very nice sound
mods
LM4562 as input IC now
shortcut on coupling cap. offset now 30mv on both channels, was 5.
output relais on MCD pcb shortcut, using a speaker protection pcb now. Is more sensitive and looks at more variations on the speaker lines, either neg. or pos.
Kind regards,
Bert
Old 23rd January 2008, 08:02 PM   #2
Good work!
I'd be interested in a comparison vs. the UcD400 amp, if possible.
Old 23rd January 2008, 08:56 PM   #3
its more on the UCD180's power level. It uses 2x30V AC like the UCD180.
But it has to break in first. After 30 hours I will compare.
Kind regards,
Bert
Old 23rd January 2008, 09:33 PM   #4
Oh, yes, it's the "smaller" MCD amp.
I'll stay tuned.
Old 25th January 2008, 10:54 AM   #5
fumac is offline fumac  China
Send a message via MSN to fumac
good job Bgt
you find an special way to install the modules
you attention that the place of the mosfet.
but the heat sink of mcd-255 is just 3mm ,
we Proposal that the best way is install to the bottom board as heat sink (if using the Aluminum bottom board )
but if your job will ok for home using ,
about the opamp, we used the dip transposon, so is very easy to replace the bb2134 with any OPs.
LM4562 is a very good op, 0.00003%
hi TheShaman
we also have high power version.
rg
fumac
Old 27th January 2008, 12:42 AM   #6
jkeny is offline jkeny  Ireland
Banned
Hi Fumac,
Looks like some excellent work on this "next generation" of class D amplifier!
Can amplifier modules be purchased?
Old 27th January 2008, 07:48 AM   #7
Fumac, the amp stays really cool. Should not be a problem.
BTW the "mosfet side" is closest to the amp. side pieces.
Sound is very..................very nice
Positioning of the modules is done for symmetry.
Crosstalk at 20khz is>100Db at full power/8Ohms/>80W/ch.
Kind regards,
Bert
Old 27th January 2008, 12:32 PM   #8
Originally posted by jkeny
Hi Fumac,
hello jkeny, not to talk about saling here, just mail to me
thanks
fumac
hi Bgt,
i'm so happy that you really like the sound from MCD-255
I do care about any modules out to the world,
all this modules is my babies.
i like them running at a good state, Healthy, and long life .
this time is winter, so the temperature is not hot.
but at summer , the temperature will rase up,
a high temperature of house will cause the more higher temperature of mosfet,
because the RDS(on) will higher when the temperature is higher,
and the RSD higher will cause more power loss into the mosfet....
this is a bad loop
so take care
about Crosstalk
if you use one transformer to one modules, Crosstalk will be best
rg
fumac
Old 28th January 2008, 03:23 PM   #9
Banned
Hi Bert,
Finished break-in yet? How do these amps compare? - would love to hear!
Old 29th January 2008, 10:43 AM   #10
jkeny,
will try to do that this weekend
Kind regards,
Bert
Page generated in 0.12009 seconds (67.79% PHP - 32.21% MySQL) with 10 queries
