| Class D Switching Power Amplifiers and Power D/A conversion |
#51 |
Hello Pieter,
Indeed, I'll have to end up with a low impedence balanced signal. It could be done with some Mosfets - I have some Exicon ECX08N16-Z which I haven't used yet - not too familiar with solid state. This would require a different interstage maybe, though I have Londahl LL1671/PP which may work. Otherwise maybe 2a3 with a small stepdown. Or 4P1L with a larger stepdown like 4.1:1. That would give 5v out for 2v in and an output impedence of around 100 ohms. I could use a pair with a LL1660/18mA and have SE in and PP out. What would you suggest? I am indeed thinking two stages like 26 into a driver stage. andy |
#52 |
I've put together a power supply with a 300VA 35+35v toroid which I hope will supply either a UcD180 or a UcD400. About +-50v output - don't need much watts in a small room.
But I have the first version of the UcD400 - Ver1.0. This has a layout similar to the current UcD400ST shown below. The OEM version layout koifarm is using to remove the two caps is a different one - is this the UcD180 OEM? On mine removing the caps would be a nightmare, since there are lots of surface mount small parts underneath. So I'll have to leave it intact. So a question about the hybrid version - which of these commercial modules can be used easily? On the HG versions there are a couple of red caps by the input - are these the ones to remove or what? Help please! I'm thinking UcD180 if I have to buy another couple of modules, but which version? First picture is my original UcD400 Ver1.0, then current models |
#53 |
#54 |
If you like to use a tubebuffer and not a inputtransformer, see below.
![]() See here for more details, 6N16 12x preamp srpp/cathode follower with printed circuit board design. Regarding the inputimpedance of the unbufferred UCD180st the "+" input has 10k impedance to ground and the "-" input has 1k8 impedance to ground. This makes to use a unbufferred UCD more difficult to use with symmetrical input. I use unbufferred UCD only with asymmetrical input. Ronny Last edited by Koifarm; 23rd February 2012 at 07:25 PM. |
#55 |
Thanks for that - looks like the UcD18o is the way to go. I was told, however, that right now the UcD400OEM is a generation ahead (some of the nCore technology) of the UcD180OEM, which will come out in a later updated version. There's also the UcD250LPOEM which you might have considered.
http://www.hypex.nl/docs/UcD250LPOEM_datasheet.pdf Andy |
#56 |
Where did you get the R-core transformer from?
"Never forget that only dead fish swim with the stream." -- Malcolm Muggeridge. "Truth cannot be brought down, rather the individual must make the effort to ascend to it." -- Jiddu Krishnamurti |
#57 |
The R Core transformer came with the housing with i used. This was a defect amplifier. But R Core transformers are sold on Ebay.
transformer r core | eBay And here: Audio Catalog Last edited by Koifarm; 28th February 2012 at 07:18 PM. |
| Question for those who have tried hypex smps with hypex modules | avian | Class D | 12 | 3rd March 2009 09:30 AM |
| Hypex UcD 180AD + signal wires, Power Supply ST, Hypex Transformer TR100A | c10h12n2 | Swap Meet | 7 | 7th July 2007 03:55 PM |
| My wacky idea for a hybrid horn loaded woofer/planar widerange hybrid loudspeaker. | Spasticteapot | Multi-Way | 0 | 30th November 2006 04:16 AM |
| FS: Hypex UcD 400/180AD, hypex toroid | Archmage | Swap Meet | 4 | 14th November 2006 04:23 AM |
| Hypex DS2.0 2 ohm | dkxdn | Class D | 9 | 23rd June 2006 01:46 PM |
| Page generated in 0.08553 seconds (85.68% PHP - 14.32% MySQL) with 11 queries |
