| Class D Switching Power Amplifiers and Power D/A conversion |
#101 | |
Banned
I was also thinking of a way to easily test different configurations of the output capacitor by removing the existing one & putting in its place two single pin dip sockets which would allow easy placement & removal of capacitors + bypass. If done for one channel, this could be used to finalise a suitable output cap configuraton! |
#102 |
#103 |
Banned
Jeez, eld,
These are expensive - $7 each. It doesn't even give the capacitance/voltage - I presume they are the 50V/1000uF caps used in the amp? Is there anywhere to find a datasheet - they would want to be good for the price. Google search finds nothing! |
#104 |
Jkeny,
They are the exact caps in receiver (1000uF/50V). I have put in a suggestion to Digi-Key to carry them if possible. I cannot find the data sheet as well. The ZE is larger than the XE and probably have a little more punch, I guess that is why it's in the PSU. I'm not sure if the XR45 have the FM or ZE caps in the output stage, but they have been replace by the XE. Boulder Cables indicated they sound better than what's in the XR45 so it's definitely an upgrade. It would be nice to have the schematic to the XR45 as well, do you know if you can find it? |
#105 | |
Banned
Do you know any other mods Boulder have done? I'm sure I can get the XR45 Service Manual - I will return Edit: If I can't get it from sharefx.com for free then you can get it along with SA-XR10 & others from manualsparadise.com for $11 for each manual |
#106 |
Jkeny,
Sorry if I'm causing confusion. The critical caps, XE and ZE, are still the same on the two models (Water caps and PS caps). The 820uF/50v change I was refering to are on the speaker board, shunting to ground for each positive and negative speaker line. I think these are the filter caps? BTW, I forgot to meantion that the Silmic II I order are 470uF/50v so I have to double up to compare. |
#107 | |
Banned
I thought you were talking about the output caps next to inductor? As I said, I would be concerned about peeling off traces during the many soldering on & taking off different caps in the output section - did you ever consider the idea of putting hollow pins into the holes where the caps were & fitting your cap leads into these pins much like a dip op-amp sits into a dip socket? |
#108 |
The parts list almost everything as pF, even the power supply and smoothing caps. I should have stuck to the schematic values. Thanks! Now I can see changing them to MKP a worthwhile endeavor.
The output caps (next to the inductors) and PS caps are still the same (XE and ZE respectively). The hollow pins are a great idea for testing the caps. I was actually thinking of putting test wires in where the ZE caps used to sit and have all the comparison caps on one outboard. Testing would be done by moving the wires from the each set of caps. What do you think? |
#109 |
Banned
Yep, That's a good idea but the length of wire plus the wire on the board to the caps may give rise to added inductance, small but might confuse results? I don't really know!
Just don't strip off the copper trace!! How good are the pcbs, maybe you can say when you tried removing cap! I order the XR57 from J&R - open box @ $218 + shipping & Tax $254 - just saw I could have got it from AMAZON for 230$ free shipping but this was black - the one I ordered was silver, my preference. Still I'm a happy bunny! Shipped it to my friend's audiophile bro-in-law, he will test & listen for a month & I get it end of Feb! |
#110 |
Nice, jkeny.
I have a silver one too. It looks pretty decent for a budget receiver. I hope your friend's bro-in-law remembers that the stock unit has a lot of compromises built in. ![]() Update on the rewiring, I got a chance to changed out the stock binding posts and updated the wires to 14 AWG long grain copper. The wires are coming directly from the main board to the pure copper posts. I only got a chance to listen to it for about 5 mins this morning, but the change was not subtle! Well worth the effort. BTW, You will need those filter caps. I will update once I get a chance to listen to it some more and will try to post some pics. Cheers, Eld |
| For Sale: Tube Amps, Class-A Amps, BG Ribbons, Chassis and Other Goodies! | opc | Swap Meet | 23 | 2nd November 2009 05:04 PM |
| FS - Class D Panasonic SA XR55 HT Receiver | t-head | Swap Meet | 2 | 29th December 2008 12:12 AM |
| New Panasonic AVR is it class D? | evad | Digital Source | 0 | 2nd July 2008 05:19 PM |
| panasonic SA-XR10 vs Tripath amps | jkeny | Class D | 0 | 9th August 2005 01:49 AM |
