T106-2 core vs.??? core Amplifier problem - Page 3 - diyAudio
Go Back   Home > Forums > Amplifiers > Class D
Old 18th March 2011, 11:11 PM   #21
nigelwright7557's Avatar
Originally Posted by zox2003 View Post
OK...
Amplifier is fixed...I used Eva's advice and inserted 100uF capacitor in series with 1K that goes from pin 2 to GND (LM311) + I added variable resistor (5K) to offset adj. pins on LM311 (with this I was able to do precise adjustment).So far so good...I am attaching updated schematic here:
Thanks,Eva
I used an XOR gate as a phase splitter to keep the gate delays the same.
Murton-Pike Systems PCBCAD51 pcb design software. http://www.murtonpikesystems.co.uk http://www.pcbcad51.co.uk
Old 18th March 2011, 11:36 PM   #22
Originally Posted by ChocoHolic View Post
More specific:
Low L can be helpful to reduce the dead time distortion. Ok.
A filter with 22uH and 1uF does show just 0.5 db overshoot at the resonance frequency when loaded with 4 Ohms.
If you go for 10uH and 2u2, then you will get 6db overshoot at 4 Ohms load.
AIR-Core Vs Ferrite-Core Inductor in Class-D amplifiers Workhorse Solid State 14 4th April 2016 02:26 PM
Which, Foil Air Core or Iron Core Inductors slhijb Multi-Way 16 20th November 2009 04:12 AM
inductor/choke/air core/ferrite core. . . same thing? poolorpond Pass Labs 24 29th March 2008 11:55 PM
Solen Air core inductors, Hammond Iron core. gnomus Swap Meet 0 30th July 2004 02:28 AM
Any website reference for diy choke ,siliver R-core, C-core, EI and power transformer bmpa Parts 2 22nd April 2004 05:15 AM
Copyright 1999-2017 diyAudio
