T106-2 core vs.??? core Amplifier problem
Old 8th January 2008, 08:27 PM   #11
Eva is offline Eva  Spain
Eva's Avatar
Send a message via MSN to Eva
44 turns on T106-2 should give 26uH which is a suitable inductance value. Wire gauge is not critical as long as it can handle speaker current without overheating. With +/-40V rails, 680nF output capacitor, and 300Khz idle operation this should produce a bit over 1Vp-p carrier residual. If it doesn't then there is something wrong with your circuit.
I bet the offset has been always there but at first you just didn't notice. You can try comparing one channel with the old inductor against other with the new (if you are enough scientific minded).
I use to feel like the small child in The Emperor's New Clothes tale
Old 8th January 2008, 08:30 PM   #12
zox2003 is offline zox2003  United States
Eva I have 470nF on output currently...I will just add some turns to reach same effect like with 680nF
Just to remind you that I loaded these modules to full power (with old core) and they worked beatifully.So I do not see what would be 'wrong' with circuit.....Maybe....
Old 8th January 2008, 08:48 PM   #13
And as far as offset...I use same PCB and just swapped inductor and that is where I have seen DC offset problem (THAT is my main problem) so it was not there with old inductor....MEASURED 100%...That is a first thing I checked on both versions (old/new inductor)...
Old 9th January 2008, 02:58 PM   #14
OK...
Amplifier is fixed...I used Eva's advice and inserted 100uF capacitor in series with 1K that goes from pin 2 to GND (LM311) + I added variable resistor (5K) to offset adj. pins on LM311 (with this I was able to do precise adjustment).So far so good...I am attaching updated schematic here:
Thanks,Eva
Old 9th January 2008, 05:01 PM   #15
fernando_g is offline fernando_g  United States
zox2003;
I'm really glad that you've your amplifier working right, and that you've learned a new circuit trick.
But I do have a question for you, I also need to learn some circuit tricks myself: why do you have the 5 CD4069 inverters in series? Do you want to create a delay?
Old 9th January 2008, 07:03 PM   #16
Yes, that is why I used 5 of them (inverting + creating delay time).
Old 17th March 2011, 11:00 PM   #17
nigelwright7557 is offline nigelwright7557  United Kingdom
nigelwright7557's Avatar
Inductors in class d are a minefield for the uninitiated.
I used power inductors to start with and they got very hot around 120 degrees.
Someone suggested a t106-2 core, I found this with 2 yards of SWG18 worked fine with my class d amplifier. It doesnt even get warm. I also found a little extra inductance didnt load the amplifier quite as much.
You are finding different levels of carrier on the output due to different inductances.
The inductance is basically a voltage divider with the output capacitor.
PCBCAD51 pcb design software. 2018 version out now with lower prices >> http://www.murtonpikesystems.co.uk
Old 18th March 2011, 12:25 PM   #18
Th3 uN1Qu3 is offline Th3 uN1Qu3  Romania
Send a message via Yahoo to Th3 uN1Qu3
You have to take into account that more inductance + less capacitance = higher output impedance, which means higher filter overshoot and higher distortion at low ohm loads.
"Audio grade" components simply means that they failed at a more critical job.
Old 18th March 2011, 01:30 PM   #19
luka is offline luka  Slovenia
luka's Avatar
yes, lower the inductance, low the THD
That why Tripath and other with HIGH freq. have low THD from output filter
home page @ http://www.classdaudio.tk/ @ 24/7 all year long
I FEEL SLOVENIA
Old 18th March 2011, 10:03 PM   #20
ChocoHolic is offline ChocoHolic  Germany
T106-2 core vs.??? core Amplifier problemHide this!Advertise here!
AIR-Core Vs Ferrite-Core Inductor in Class-D amplifiers Workhorse Solid State 14 4th April 2016 01:26 PM
Which, Foil Air Core or Iron Core Inductors slhijb Multi-Way 16 20th November 2009 03:12 AM
inductor/choke/air core/ferrite core. . . same thing? poolorpond Pass Labs 24 29th March 2008 10:55 PM
Solen Air core inductors, Hammond Iron core. gnomus Swap Meet 0 30th July 2004 01:28 AM
Any website reference for diy choke ,siliver R-core, C-core, EI and power transformer bmpa Parts 2 22nd April 2004 04:15 AM
