typical unwanted amp byproducts
Old 8th January 2008, 05:10 PM   #11
fernando_g is offline fernando_g  United States
I've used these inductors previously, but at frequencies not much higher than 100 Khz.
Although the data sheet does not mention the core material specifically, or its operating frequency, there are two key words in the datasheet: "Low Cost".
This would essentially mean a low grade core, which would have excessive losses at the frequencies you are working with.
The same vendor offers the same 2200-series of toroids, in a low core-loss format.
Check out the following link: http://www.bourns.com/pdfs/2200ll_series.pdf
Old 15th January 2008, 02:42 AM   #12
gearheadgene is offline gearheadgene  United States
gearheadgene's Avatar
fyi - I played some audio through the amp for the first time tonight. It sounds pretty good! Nothing is optimized yet. The audio source is an MP3 player that really doesn't have enough zip to drive the amp to full output - yet it's pretty loud.
One thing that stands out immediately is that there is some pretty obvious high frequency hiss coming from the mid-range and tweeter. Even with the input removed, the amp is generating this noise. Can anyone comment on acceptable or typical noise floor?
I attached a picture of the lab/garage with the amp running!
Old 17th January 2008, 06:19 PM   #13
Cheops is offline Cheops  Estonia
The core material is iron powder and the color marking is yellow-white(seen on the second picture, probably T106-26 type).Its not intended to work at these frequencies(400kHz in your project).Those are used in SMPS at some 20...25kHz.But they will do OK if u use them in rail voltage filters.In my last project I tried T106-2(color marking red or red-dark green).In my project they donīt even get warm.Here is some pretty cool calculator.
http://www.66pacific.com/calculators/toroid_calc.aspx
BTW The original schematic is not mine
typical unwanted amp byproductsHide this!Advertise here!
sub making unwanted noises busterno1 Subwoofers 3 26th August 2007 10:12 AM
unwanted spying and listning in my home andrew2007 Everything Else 17 1st May 2007 06:36 AM
Typical 2A3 hum? bobhayes Tubes / Valves 31 17th October 2005 01:12 PM
