| Class D Switching Power Amplifiers and Power D/A conversion |
I have slowed my testing on various bypassed input caps because of some of the comments regarding my test bed. I have given a lot of thought to the various implementation schemes.
The way the test bed is currently configured I can place the electrolytic to be bypassed about 2-inches from the input on the PCB. The bypassed can then be switched in via a rotary switch. This rotary switch adds another 6-inches of Teflon clad wire between the bypass caps and the input cap. It has been pointed out to me that the bypassed caps should be as close as possible to the PCB. I can place the bypasses closer to the PCB and switch in various input caps, but this approach limits the bypasses that can be tested. This approach requires me to solder each set of bypasses and to hardwire them in to the circuit. This limits my variability and requires considerable time to set up. What has made my testing to date manageable was the ability to compare one cap against another. Soldering and manually switching just takes time and basically just slows me down. So, I just would like input from those that my be able to propose an alternative that that will make the test viable and the test bed flexible. Help!
Davet |
#2 |
When I undertook the original Tripath input coupling capacitor tests, I tested only the caps I had on hand. During my testing caps and circuits were donated for testing. The caps I have immediately available for bypassing are extremely limited and not up to "modern" audiophile standards.
I am looking for recommendations for bypass caps. I have plenty of input caps I just need suggestions on bypass caps. Considering, how inexpensive bypass caps are I am willing to purchase a few topologies. I am willing to make an order from Digi-Key. If you have a bypass topology that you would like to have tested that is available from Digi-Key please send and email of the proposed topology and the Digi-Key part number to: Davet.diy@hotmail.com. I don't have the time or the inclination to order from numerous sources. Contact me via the above email address for any proposed topologies for donation or loan. Test results will be posted under the original Tripath Input Coupling Capacitor thread.
Davet |
#3 |
Hi Dave,
Can you post the schematic of the input area, from the Input RCA Jacks wiring to the PCB to a couple of components past the Input caps? Is the picture of the amp of this area in the other thread? Thanks! Regards//Keith
If Wile E. Coyote had enough money to buy all that ACME ****, why didn't he just buy dinner? |
#4 |
test in mono, use different caps on each channel?
you only need a decent DPDT relay for the output, parallel the inputs. If the difference in caps is less than the difference in left-right in the same amp then it doesn't matter.
Help some guys with funny hair bang two rocks together really hard. http://athome.web.cern.ch/athome/LHCathome/whatis.html |
#5 |
Hi Dave,
I got the schematic, Thanks! Do you have a top down picture of the input area of the amp upto and a little past the input caps? This way I can think about this! BTW, I like Mike's idea! Thanks! Regards//Keith
| Tripath Input Coupling Caps | Davet | Class D | 424 | 8th January 2012 01:32 PM |
| DC coupling circuit for Tripath amps | theAnonymous1 | Class D | 3 | 23rd June 2009 07:08 PM |
| Creek CAS 4040 problems and speaker coupling electrolytic query | bikelectro | Solid State | 0 | 7th May 2008 03:11 PM |
| Electrolytic to film - Retain the bypass in coupling app? | HaflerFreak | Parts | 17 | 3rd March 2008 09:43 AM |
| ECC83/12AX7 Tube test query | waam68 | Tubes / Valves | 8 | 8th November 2007 08:52 PM |
| Page generated in 0.09959 seconds (76.31% PHP - 23.69% MySQL) with 10 queries |
