| Class D Switching Power Amplifiers and Power D/A conversion |
diyAudio Moderator Emeritus
I SIM this simple classD output stage. It's like Behringer output stage, with turnoff transistors.
The driver is idealized Vpulse, +/-10V p-p, rise/fall time=10ns, 2uS period and 0.5uS on-time (to reflect working under load). The load is 1.5ohm. |
#2 |
"Vss#branch" is Vss current.
It shows severe cross conduction between 0->15A (lower mosfet) and -10->-25A (upper mosfet). What/who makes this cross conduction? Is it caused by dead time? |
#3 |
It looks like the reverse recovery transient and it corresponds with the off time of about 100ns plus the reverse recovery time of 100ns in the IRF530 datasheet.
Brian |
#4 |
Hi, BWRX,
Thanks for the input Is there any trick to eliminate this cross conduction? I tried with IRF540-9540 and they are worse. Why this cross conduction don't show up if I make on-time 1uS (50% of 2uS), and become worse with smaller dead time? |
#5 |
I'm really curious and make this SIM. Upper mosfet is driven by ideal square wave V1, off=35V, on=45V.
Lower mosfet is driven by V2, off=-45V, on=-35V. Both T=2uS, Ton=0.5uS, rise/fall time=10ns. |
#6 |
and I still get this :
There are 2 cross conductions now. How can we advoid this "mosfet inherent recovery time" problem? |
#7 |
Adding a snubber at the switching node may help some.
Brian |
#8 |
Try adding a 200ohm resistor in series with D2 and an RC snubber (R=10ohms, C=0.22uF) between VDD and SW. That helps get rid of some of the cross conduction but not all of it. I can post the switchercad files of the simulation I cobbled together in a little bit.
Brian |
#9 |
Hi David,
R1,R2 should be atleast 1K or even less to speedup turn-off and insert the Rg as said by BWRX to slow turn-On time. Trr=100nS is enough fast if the SWF=300KHZ even, in Class-D operation Kanwar
It's a fruitless endeavor to try and educate a fool that rejoices in ignorance
#10 |
There is a good paper on body dioda Qrr, IR AN-967.
It's really a problem in high speed switching. This cross conduction won't show up in idle, but appears in modulated/loaded condition. I wonder how Fumac get away with this in Mhz modulation, this Trr will be very big compared to the Mhz timing period. BWRX, Kanwar, I will try to sim your suggestions, thanks. |
| Cross-conduction - how to avoid? | ceharden | Solid State | 24 | 18th February 2009 10:08 AM |
| CCRT– Cross Conduction Reduction Topology | phase_accurate | Class D | 20 | 9th March 2008 11:55 AM |
| Need a cross ref # | clayton | Car Audio | 2 | 27th November 2007 01:00 PM |
| Holton's N-Channel amp Exhibits Severe Cross-Conduction at high Input signal. | Workhorse | Solid State | 106 | 13th November 2004 06:04 AM |
| N-Channel Mosfet Linear amp Open Circuit Cross - Conduction | Workhorse | Solid State | 21 | 21st July 2004 09:11 PM |
| Page generated in 0.13875 seconds (60.04% PHP - 39.96% MySQL) with 11 queries |
