looking for pmh3000 behringer power mixer schematics - Page 8 - diyAudio
Go Back   Home > Forums > Amplifiers > Class D
Old 1st June 2010, 12:23 AM   #71
Default Pmh880s
Does anyone have service manual or schematic of PMH880S?
Please send me to mail bdjinovic@gmail.com
thank you
Old 1st June 2010, 06:15 AM   #72
cakum is offline cakum  Thailand
I need the schematics and service manual for a Behringer PMH1000 powered mixer. My email is: pornchai@solution-corp.com
Thans you
Old 21st June 2010, 08:57 PM   #73
Default Berhinger PMX5000 power supply
Hi All,
Can anyone help with a circuit diagram of the Berhinger PMX5000.
steveyjennings@hotmail.com
Thanks in advance for any help given.
Old 14th July 2010, 04:23 PM   #74
rezamir is offline rezamir  Iran
hca8001 datasheet ?
Old 23rd July 2010, 07:35 AM   #75
Tarzan is offline Tarzan  Belgium
Tarzan's Avatar
For the PMH3000;
A blown PSU. 2 SMD resistors with value 0.047 Ohm are open.
A diode is gone to. A cap 4.7u/450V has bursted.
A schematic of the psu would be handy and very much appreciated if it could be mailed.
The amp is the same as of the PMH5000 and I not checked yet.
Schematic of the 5000 is available, but no psu in it.
Tarzan
Old 23rd July 2010, 11:58 AM   #76
Hi. I don't suppose you could send me a schematic of the DPA300-2 circuit. The PMH1000 set of schematics has the power amp in the set of schematics, but the circuitry does vary from the PMH to the PMP. There are different components designated. Ihave a Behringer PMP1000.
The SMPS is te same, and this has been repaired ok. It sends power great to the power amp....it fires up for about 15 seconds after the Speakon relay kicks in but fizzles out to a crackle in the very far background...when you power down, then power back on after say 2 seconds...the same happens.
Old 18th August 2010, 06:19 PM   #77
Default Behringer Eurodesk MX9000 PSU Schematic needed
I need the schematic for the power supply (PSU) to a Behringer Eurodesk MX9000. Any assistance would be greatly appreciated!
Thanks!
Old 18th August 2010, 07:34 PM   #78
LAJ is offline LAJ  United States
Default I once worked for a depot station...
and I can tell you what goes wrong with the mixer output modules. The output IRFs blow and they take out the .1 ohm resistor in the heat shrink tubing. If that doesn't fix it, you may have an open trace in the middle. Its a multilayer board (5 layers I think). You'll need a schematic if thats it. I've never seen any trouble with the front end D to A converter on these. Some I have been unable to fix however and had to order a new module. Good luck.
Old 18th August 2010, 08:16 PM   #79
Smile all fixed
I replaced the IRF's (640's and 9640's...all of them as a matter of course, only cost pennies) Prior to this...quite right, 2 of the negative rail .01ohm resistors were open. There was a cracked trace with one of the (15v)Z.diodes. All done and powering on and giving great output.
The PMP1000 shematics differ from the PMH1000 schematics when it came to the power amp. Thanks for your input
Old 27th August 2010, 05:11 PM   #80
Default More Info
The PMP series uses a different amp module from the PMX (or PMH) series thats supposed to be more reliable. The PMX2000 is a box mixer and uses bipolar outputs (1943/5200). Those are real fun to take apart.
Most problems on the mixer board is due to a bad input opamp (4580). Make sure there is no dc on pins 1 or 7. And 4 and 8 should have + and - 15.
An apparant loss of one channel is usually a bad output fader. Its the only stereo one in the board. Looks just like the mono faders. Changing pots or faders requires removal of all knobs and nuts from the front of the board. (Its helpful to make a crude map of the knob colors to speed re-assembly.)
If the SMPS won't come on after repair, the problem is usually one or more bad diodes on the secondary side. They'll check good on a meter but simply won't work at the 80kHz coming out of the transformer.
Overall its a good board for the money. I like it better than the Mackie since the opamps are accessible. (To change an opamp on a Mackie, it requires dissassembly from the front panel.)
The email of their service dept is Servusa@Behringer.Com. Haven't used it in quite a while so it may not work any more. Good luck.
Need service manual or schematics of behringer PMH1000 mixer fredos Class D 18 7th October 2010 03:11 PM
behringer pmh3000 abelis Parts 2 3rd July 2009 11:47 AM
Behringer EuroDesk MX9000 mixer problem - Help!!! Molasar Power Supplies 7 13th November 2007 05:01 PM
Copyright 1999-2017 diyAudio
