| Class D Switching Power Amplifiers and Power D/A conversion |
Maybe someone can assit me with a troubleshooting idea.
From time to time I get class D amps repaired, ...the typical blown output FET or power supply FETS blown to pieces. But I notice that on some amps I hear a high pitch whine in the speaker. I question weather this is normal or is there a problem. I use a full range speaker to troubleshoot and I am thinking maybe thats why i hear it... or is there really a problem... if you scope the output of the class D amp, what would one expect to see ? power supply noise or high frequecy noise from the switch on and off of the H bridge? Tom |
#2 |
If you scope the output you should just see the remains of the carrier. Should be a fuzzy sine wave.
Setting the scope to normal audio sweep rates should show you the same sine wave, but of course as an indistinct block or fuzzy line. You can measure DC offset that way, too. That's all you really should see. On the power rail you will see the switching fundamental plus a lot of other noise. Be careful with grounds and the scope probe on BTL amps!
Take the Speaker Voltage Test! |
#3 |
Maybe is talking about beating probleme...Watch syncronisation between channel and power supply...
Fredos |
#4 |
I have never heard or that before, could you explain that?
Do you mean a 60 HZ issue with an input that has a hot ground? |
#5 |
Beating is made of switching residual on un-syncronized signal. If a channel run at 330Khz and the second one at 340Khz, you have about 10Khz of difference between them. This will make an audible 10Khz modulation over signal...And worst, if frequency of them are not stable, you will modulate the 10Khz difference...Imagine! Add to this a switching supply running at 108Khz (for example!), you will add another 16Khz of shifting to the modulated interference (beating), ie: third harmonic of 108Khz will be at 324Khz...And to worst that a bit more, use more than 2 stereo amplifier that dont have stable crystal reference......
More clear now? Fredos |
#6 |
Yes, I see what your talking about, but I guess since I cant see the schematic of the power supply, I can't actully test this.
Moreover is some acceptable, if bass is the primary frequency, would you even hear a 10 - 15KHZ signal thru the speaker... |
#7 |
With some woofer, yes!
Fredos |
#8 |
Beating frequencies are only charactetistic of clocked systems. Crosstalk between self-oscillating systems manifests itself as noise.
I use to feel like the small child in The Emperor's New Clothes tale
#9 |
I already experience beating with self oscilating design...Specialy when they are supply by a SMPS and feed to a high effiency speaker (100db and more..)...
Fredos |
#10 |
Well, perhaps back to my original thread...how do you troubleshoot this?
| Hum to noise problem with class A chipamp | ionomolo | Chip Amps | 5 | 2nd June 2008 03:48 PM |
| Noise problems in non discrete class-d amp | Baldin | Class D | 26 | 18th February 2007 08:00 AM |
| Troubleshooting Audio and Video Noise | Arius | Parts | 0 | 25th May 2006 09:45 PM |
| Class D troubleshooting | bknauss | Class D | 3 | 17th July 2004 01:49 AM |
| Page generated in 0.09161 seconds (78.52% PHP - 21.48% MySQL) with 10 queries |
