| Class D Switching Power Amplifiers and Power D/A conversion |
I need a little help, and hoping someone can lend a hand. I’m looking to put two Trends amps in one case. My first option was to just use one external power supply, but since I have a large case, I would like to keep the powers supply internal with only one AC power cord.
I’m wondering if I can use two of these: http://www.autocostruire.com/catalog...67f2052ae29707 and one of these: http://www.autocostruire.com/catalog...roducts_id=265 if this will do the trick, or if I would have to add anything? Thanks in advance NH |
#2 |
Why go all the way to Italy? There are plenty of good power supplies in North America. And they will be 120V 60Hz ready.
You could even use 2 small SMPS, if you want to keep things seperate.
Take the Speaker Voltage Test! |
#3 |
I did look at the option of using two seperate power supplies, but I want it all in the case. Can you point me to where I can this stuff on this side of the pond
#4 |
I have a similar need. Does anyone know where I can find a reasonably priced 12V~14V SMPS that will put out at least 5 to 6 amps?? Chassis, not wall wart, is preferred.
Thanks in advance for any help.
Nihilism is best done by professionals. |
#5 |
http://apexjr.com
Go to the new section. Scroll down to almost the end. There are three versions listed. I use the highest current version. Originally used in a fax machine iirc. Andrew
None of us are leaving this world alive. Enjoy it responsibly as you may. |
#6 |
Thank you Andrewbee, that looks good. and the price is certainly right. I will probably order one tomorrow.
I also found thise: Ebay item 230196513004 sold by Sure Electronics It costs more but seems to be smaller.
| trends TA-10 ideal power requirements | jeremyrosehifi | Class D | 4 | 29th April 2009 03:03 PM |
| Pre-out on the Trends TA-10.1 | mickiii | Class D | 4 | 19th December 2008 01:04 AM |
| SLA battery power for Trends TA10.1 | aquapiranha | Class D | 4 | 4th March 2008 09:24 PM |
| Power for 3 Trends Amps | Nappyhead | Class D | 4 | 27th September 2007 12:01 AM |
| Page generated in 0.08809 seconds (76.94% PHP - 23.06% MySQL) with 10 queries |
