simple heat sink, how to make? simple heat sink, how to make? - diyAudio
Old 28th November 2007, 12:03 AM   #1
gychang is offline gychang  United States
Default simple heat sink, how to make?
Apologize if this is wrong forum.
I put together an amp6 and need to make a heat sink about 1x3" for the tripath chip/voltage regulator/rectifier.
I have some thin aluminum plates and thinking about making my own?, what can I use to "glue" the 90degree fins?, is there a conductive silicon glue that may work?
anyone have experience?
thanks,
gychang
Old 28th November 2007, 01:04 AM   #2
Aengus is offline Aengus  Canada
Aengus's Avatar
"Arctic Silver Thermal Adhesive" is said to do this - I have no personal experience with it.
Manufacturer's instructions here.
One source here (don't know anything about them, just googled it).
Please let us know how it works if you try it.
Regards.
Aengus
Old 28th November 2007, 01:32 AM   #3
Regards.
Aengus
thanks, that may work, newegg has it. I was wondering how I can make fins (glue to aluminum to aluminum), not sure if this will do it.
I seem to remember seeing "heatsink DIY" somewhere.
gychang
Old 28th November 2007, 01:53 AM   #4
Magura is offline Magura  Denmark
Magura's Avatar
gychang
Regular epoxy will do just fine, and at a fraction of the cost.
Magura
Everything is possible....to do the impossible just takes a little while longer.
www.class-a-labs.com
Old 28th November 2007, 02:34 AM   #5
amt is offline amt  United States
Thats quite alot of work for an appropriate heatsink. And the fins wont dissipate must of the heat since the epoxy will insulate them from the plate. A big piece of AL should be enough. I cut slices with a bandsaw around the perimeter or just on 3 sides depending on the clearance needed. They can be carefully bent 90 degrees but I ususally dont bother.
amt
Old 28th November 2007, 02:43 AM   #6
This is the easiest way though. Use a piece of "L" channel and attach the chip etc to one leg and mount the PCB to the other. It provides a large sink that also makes mounting the board a snap. Heres a Charlize using this method.
amt
Old 28th November 2007, 10:10 AM   #7
amt
thanks so much amt. what thermal adhesive work for you?
gychang
Old 28th November 2007, 01:21 PM   #8
theAnonymous1 is online now theAnonymous1  United States
theAnonymous1's Avatar
I use J-B KWIK Weld for all my heatsinking needs. It's good to 300 degrees Fahrenheit and seems to have good thermal transfer properties. A whole lot cheaper than the Arctic stuff too.
http://jbweld.net/products/jbkwik.php
Old 28th November 2007, 03:19 PM   #9
that's very helpful, I see this stuff in the auto parts store all the time.
gychang
Old 28th November 2007, 04:03 PM   #10
gychang,
I use standard zinc oxide/silicon thermal paste - GC brand which is available everywhere. This is more that adequate for the minimal heat generated by these tiny amps/regs. Just make sure the mating surfaces are as flat and smooth as possible. If the heatsink material is not, use a sanding block with #1000 wet/dry and level it out.
If you havent read this yet, do so. Good information and explainations regarding heatsinking.
http://sound.westhost.com/heatsinks.htm#9
amt
simple heat sink, how to make?Hide this!Advertise here!
Advise on heat sink pmchoong Pass Labs 13 13th August 2011 05:50 PM
voltage reg make heat sink live. Bad idea? phrarod Tubes / Valves 4 10th December 2008 12:57 AM
Need ideas to make heat sink with this plate space2000 Solid State 11 1st August 2008 07:07 AM
Heat sink and chokes FS broadcast guy Swap Meet 0 22nd November 2004 07:23 PM
How much heat sink is necessary? rosss Pass Labs 11 23rd February 2003 05:23 AM
Copyright 1999-2017 diyAudio
