| Class D Switching Power Amplifiers and Power D/A conversion |
I have repackaged one of my SI T-amps but am having a couple of problems:
1. LED not working even though I have 12 volts on the wires going to it. New LED time, or did I miss something? 2. I don't want or need a volume control. To simply go directly from RCA's to the board, which of the white wires do I solder to the RCA's? Right now, if you look at the board from above, with the edge connector closest to you, the two red wires (to the power switch) are on the left, the next two white wires are not connected, the middle white wire is connected to ground, and the two white wires furthest right are connected to the RCA's. I have power on the board but no sound. Am I using the right wires for inputs? |
#2 |
1. check for correct polarity and if you have 12v, you need a 1k5 resisistor in series with LED...
2. the 2 white wires next to the red wires go to the rca's. |
#3 |
Thanks!
| Quick SMD resistor questions | spooney | Car Audio | 3 | 30th January 2008 01:30 AM |
| Few Really Quick Pass Amp Questions | JPeitzman | Pass Labs | 30 | 17th September 2007 08:54 PM |
| 2 quick questions | JPeitzman | Chip Amps | 7 | 22nd July 2007 05:27 PM |
| 2 quick questions | Lowjacker | Car Audio | 3 | 8th July 2006 03:32 AM |
| quick questions | theChris | Multi-Way | 0 | 12th February 2003 04:54 AM |
| Page generated in 0.07974 seconds (68.88% PHP - 31.12% MySQL) with 10 queries |
