| Class D Switching Power Amplifiers and Power D/A conversion |
#381 |
Another picture, since I did not know how to attach more than one.
The vol pot fits perfectly well where the red panel IR sensor used to be. |
#382 |
Very nice Cheric. I love the big Obbligato caps. The picture makes them look tiny. That's an impressive first project.
#383 |
I had an idea last time when i was at the beach listning to my micro speakers ( Class D 2X2 watt Eutech IC )
I thought, this can be better, but it should still be a small efficient amplifier as it will be battery powered. So i went to the market and bought a small black housing and tried to fit one of my TA2024 PCB's in there Ofcource, it didnt fit hehe so i had to remove 1 MM of PCB at both sides to make it fit Also bought 3 X 3.7 volts 1000mA polymer cells and a protection PCB for charge and distcharge protection. so 12 volts all together to power the PCB, 2 3.5 mm Connections, one input, one output simple switch on the front side, and a blue LED above the power switch. The result is a light weight durable and well sounding ampifier now i need to design and make some speakers, i aready have 2 5 watt speakers that look very nice, with rare earth magnets and a very nice suspention.... ill keep you guy's posted!
Always check the power supply... and my spelling... |
#384 |
hereyago the back side!
#385 |
This is the inside without batteries lucky me, those polymer batteries are very thin!
#386 |
Could you tell me the maximum voltage of the fully charged polymer batteries? I've been wanting to try them for a while.
#387 | |
4.2v I think... Arjen: Put me down for 4 tripath boards. I'll send you an e-mail.
#388 |
Hi Arjen,
I may order some boards (although I have a large backlog of PCBs and kits yet to finish and task!) but how about selling on some of those cases and knobs? It seems to be hard to find good-looking cheap ones in the UK Chris |
#389 | |
I know this is a newbie question, but I am... ![]() I noticed that you put 3 large yellow capacitors in the speaker connectors and there is a blue cable connected on the right hand side of the box for ground. Can you please let me know why those capacitors are needed, what values should I pick and where to connect them it's not easy to see this in the picture you provided, I barely see the connections and I'm not sure. As you are not using a pot, do you need a preamp to use the amp? Where should I connect the ground cable? Please don't laugh... Thanks! |
#390 |
Is there anybody that could answer me?
